Old 08-04-2017, 02:17 PM   #1
68is4me
68is4me's Avatar
Re: Spark Plugs What is wrong?
Do a leak down test sounds more like a mechanical issue. Also check and make sure that the power feed for the distributer is a full voltage and not the factory resistance wire.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 08-04-2017, 07:41 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Cyl 3,4 and 6 all look like water contamination within the combustion chamber...
Compression test and leak down test...most likely blown head gasket between 4 and 6...
Could also be a lean out due to manifold crack...is this a two barrel or four barrel carb?
Open plenum manifold or closed ?
AussieinNC is offline   Reply With Quote
Old 08-04-2017, 08:01 PM   #3
Grumpy old man
Grumpy old man's Avatar
I would get a correct set of matched plugs gapped correctly and run it again before you get too crazy trying to diagnose whats wrong , the threads don't even look the same length let alone the heat range can't be the same .
Old 08-04-2017, 10:33 PM   #4
53chevyforever
53chevyforever's Avatar
I had all the same at first...they looked fouled so bought all new ac plugs at beginning...no difference...then this last try...I put in the 3 autolites...still ran the same.
53chevyforever is offline   Reply With Quote
Old 08-04-2017, 10:29 PM   #5
53chevyforever
Manifold is edelbrock performer bought new from oriellys by the guy I
bought truck from....carbs are not the problem both that I have tried run
perfect on my other truck.
