Old 08-05-2017, 08:27 AM   #10
mongocanfly
mongocanfly's Avatar
Re: LS Cooling Issue
if you change thermostat don't forget to repeat the engine block fill procedure by filling thru the top hose...
also have you verified the belt routing yet? making sure the pump is rotating in the right direction...I know a guy that had his backwards . .his pump mounted fan was pushing air thru the radiator to the front. .
