Old 08-06-2017, 01:24 PM   #1
Sawlog
How much hp gain?
I recently replaced the iron heads on my truck and changed the cam. 350ci
My old heads were 72cc with 1.94intake and 1.60 exhaust. Cam was stock.
My new remanufactured heads have 64cc chambers with new 2.02 and 1.80 valves. The intake and exhaust ports were opened up too. My dad called it gasket matched?
New cam is summit 1102, 204-214 at .50. 421-444 lift.
My question is... is there any way to guess how much of a horse power gain it made?
Thank you
Sawlog is offline   Reply With Quote
Old 08-07-2017, 06:58 PM   #2
tdangle
tdangle's Avatar
Re: How much hp gain?
how does it feel? more power off idle or in the upper RPM ranges?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-07-2017, 07:03 PM   #3
Sawlog
I would say lower range
Old 08-07-2017, 07:19 PM   #4
mongocanfly
mongocanfly's Avatar
other than a wild guesstimate ..only way to know for sure would be stick it on a dyno
Old 08-07-2017, 08:57 PM   #5
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Go on comp cams site.Look for cam quest.You can build your motor and it will tell you what hp you are at.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 08-07-2017, 09:18 PM   #6
hjewell2
hjewell2's Avatar
Thank you
went from 165 to 250 maybe 275 hp
hjewell2 is offline   Reply With Quote
Old 08-08-2017, 06:40 AM   #7
cadillac_al
That Performer cam is bigger than the factory 350 hp cams but I really don't believe it would make 300 hp. I'm with hjewell2 that it is more likely 250-275.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-16-2017, 08:58 AM   #8
tjsblazer
tjsblazer's Avatar
Camquest is typically generous in their ratings. After all they are trying to sell performance upgrade parts. Anything outside of a calibrated dyno run is just a guess which is essentially what you asked for, I guess ...
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 08-17-2017, 06:37 PM   #9
mattfranklin
mattfranklin's Avatar
Years ago I had a program called "Desktop Dyno" that had lots of options. It worked pretty well, of course the % change guesses were more useful than the absolute numbers. Not sure if it's still around.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 08-30-2017, 11:59 AM   #10
Coley
Coley's Avatar
What type of intake manifold do you have (single plane? or dual plane? type?)...and what type of Carb?
Also, what type of ignition?...HEI?...was the motor in good condition with good compression and in good tune?
All of this has a major bearing on performance in addition to internal mechanical upgrades.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 08-30-2017, 01:01 PM   #11
Kudzupatch
Kudzupatch's Avatar
Yup! So many variables. Was the engine and fuel system tuned to take advantage of the extra potential? There is more to it than just bolting on parts. Need to be tuned to take advantage of the potential there.
Big fan of Engine Masters show but if you pay close attention you hear them mention Steve has run the engine several times off camera tuning it before the Final Pull they usually show. There is a lot of work goes on to find all that HP.
Kudzupatch is offline   Reply With Quote
Old 08-30-2017, 12:34 PM   #12
mattfranklin
Another nice reference is the "Engine Masters" youtube show (also on Motor Trend on Demand).
If you're lucky, they have tested parts combinations similar to yours. They try lots of stuff on the dyno.
Old 08-30-2017, 05:18 PM   #13
Tom
driving is in my blood
Tom's Avatar
1.8 exhaust valves...never heard of that size. A gasket match is not porting. Sounds like you used another set of stock iron heads with bigger valves and a 30yr old mild cam that everyone calls the "RV" cam. I'd say you gained 30hp or so.
Old 08-30-2017, 06:55 PM   #14
Sawlog
Dual plane preformer edlbrock intake with 600 cfm carb. 1.625in long tube headers with 2.5in dual exhaust hei ignition. I did compression test, 135psi on all cylinders. And yes it is tuned pretry good.
1.60 exhaust valve. Sorry.
on paper my compression should of went from 7.7 to 8.5.
It made a world of difference!
Old 09-01-2017, 12:31 PM   #15
mattfranklin
Here is an Engine Masters episode looking at original stock heads vs. Vortec head and cam upgrade:
https://www.youtube.com/watch?v=f7mv...u7srE&index=25
They changed too many things at once, but maybe the tests here will bracket what you have. Your power is probably higher than the baseline, but lower than their max case.
