Old 08-04-2017, 10:51 PM   #1
ronm69c10
overheating rat rod
purchased a 1969 c-10 with a 454 motor.engine is a stock rebuild with header's.It has been hot here in southern ,north carolina for past 3 month's.Truck is overheating,I flushed radiator and installed new thermostat. Water pump is O.K.and still overheating.I want to get a new radiator and would like advice,2,3,4, Row,aluminum or steel,what brand.Help would be greatly appreciated. Thank's Ron
ronm69c10 is offline   Reply With Quote
Old 08-04-2017, 10:54 PM   #2
CST10
CST10's Avatar
Re: overheating rat rod
4 row aluminum is what I would recommend. As far as makers, I don't have a perferance. But I would make sure it came with a shroud and electric fan set up. I think champion and griffin brands offer that option.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 08-04-2017, 10:54 PM   #3
rockyrivermark
Get a 4 row aluminum with electric fans. That would definitely help in cooling unless there is some other underlying problem.
Mark
rockyrivermark is offline   Reply With Quote
Old 08-05-2017, 12:22 AM   #4
geezer#99
geezer#99's Avatar
Before you jump into a different rad answer one question.
Do you have a coolant recovery bottle on your rad?
Old 08-05-2017, 05:21 AM   #5
Boog
laying low
Boog's Avatar
First off, welcome to the forums.
Some pics of your setup might help. You may not need a new rad. Currently 2 or 3 row radiator? Fan shroud? Fan type? Engine state of tune? Retarded ignition timing causes an engine to run hotter. Just food for thought.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-05-2017, 08:12 AM   #6
Mollzyie
Mollzyie's Avatar
Lots of good advice on this forum and congrats on your truck .... i have a 454 in my truck as well .. and it Over heats too ... when I'm cruising/moving it's fine .... haven't really gotten to fully address it yet cause I don't drive truck that much and work a lot ... I have an alum rad and new water pump just haven't put them in ... anyways .... (good advice Iv gotten here) what I have done is move my temp sensor from next to the header over to where the water pump is for a more accurate reading .... and Iv put my fans on a manual switch . Good luck dude 👍🏼
M.A.G.A.
Mollzyie is offline   Reply With Quote
Old 08-05-2017, 09:13 AM   #7
my56chevytruck
my56chevytruck's Avatar
I also have a 454 in mine, but I want to ask you a few questions. Overheating means to me fluid puking out, but it means other things to look at, is it in fact puking fluids? What temperature does the engine get up to? You can get for a few bucks a laser temperature gun and you will then know the accurate temperature your engine is getting up to. I'm running a 2 core, 1 1/2" tubes - aluminum radiator and an electric fan with an adjustable unit to come on about 170 degrees, and it runs fine. More tubes depending upon the sizes could mean a much wider radiator, do you have that kind of room and or it could mean much smaller tubes than say 2 or 3. Are you running a 50/50 mix?? Number of tubes doesn't necessarily correct an overheating issue. Others have also mentioned factors you need to look into if you already haven't.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 08-05-2017, 09:09 PM   #8
ronm69c10
No, I don't have a recovery bottle yet I planned to buy a 32 oz. when I purchase the radiator. I installed an automatic choke, adjusted carb., added new 180 thermostat and flushed radiator and new 16 lb. radiator cap. Ron
Old 08-05-2017, 09:17 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Do you have a shroud? Having one is necessary for your cooling system to function properly.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-05-2017, 09:27 PM   #10
70 shorty
Where's my beer?
70 shorty's Avatar
at what temperature is it running? Does it cool down as you drive, but heat up at stoplights?
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 08-05-2017, 09:40 PM   #11
geezer#99
geezer#99's Avatar
Then it's likely not overheating. It's just puking out fluid until it finds the right level in the rad for normal expansion. That level is normally 3 inches below the top when cold. If you keep filling it to the top it'll keep puking it out.
Old 08-05-2017, 10:22 PM   #12
RustyBucket
RustyBucket's Avatar
You didn't say what you have currently for a cooling system. My 2wd. Blazer has a mild 454 w/A.C., & headers. Has a Performer RPM intake on it. I have a stock 4 core rad. with a shroud and a G.M. 7 blade clutch fan. I have a 160* thermostat. It runs 160 - 180 normally. It'll get to 200 deg. if it idles 600 RPM for a long time on a 90 deg. Florida day. It won't blow coolant out the overflow.... no catch tank. If I bring the RPM up to 1,000rpm the temp. will start back down.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 08-05-2017, 10:41 PM   #13
Mike C
Mike C's Avatar
You also didn't say if it was getting hot idling or if it was while driving. Both require different possible solutions.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-06-2017, 09:35 PM   #14
ronm69c10
cst10 that is where I was headed,along with adding a recovery bottle. Thank's for the help RON
