Old 08-07-2017, 07:22 AM   #4
PGSigns
PGSigns's Avatar
Re: Wheel and tire width
If plan to drag race it I would look at going with a spring or a coil over rather than an air bag. The bag will be to soft of a spring rate. Also you are going to want or have to depending on how fast you plan to run go to a c clip eliminator kit on the rear or to a rear end that does not have c clips like a 9". That will also allow you to narrow the rear to get a wheel with a more centered hub. These trucks are easy to tub by just widening the stock wheel housing. There are also wider ones offered in fiberglass. Doing this will allow you to pick the tire you need verses what will fit. Then once you have the tire picked you can figure out the wheel based on you rear end and the tires shape. The section width is what you have to work with to make sure you have room on the tire. When we were building drag cars we built the rear end to match the wheel and tire choice so we could mount the tire and set the tire pressure and put it under the car. That way we were sure it all fit and we had the room we needed for the tire to move around. They get a lot taller when you do a burn out and can easily move side to side a couple of inches if you get a little crossed up.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
drag, drag radials, slicks, wheels
