Old 08-07-2017, 08:52 PM   #1
Husker
Husker's Avatar
Which Battery..
I am in need of a Battery for my 70 GMC 4x4. I got 1 a few months ago and it is already bad, Exide. Iwas thinking of an Interstate M7 AGM design. Any input would be helpful. Batteries are probaly Like Oil types/brands.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 08-07-2017, 09:02 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Which Battery..
First I'd do some checking to see why the other one drained out so fast. It would suck to drop more coin on a more expensive battery to drain that one out as well.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-07-2017, 09:22 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Which Battery..
^^ x2 what Gary said, need to find out what killed that one. Possibly it was just a fluke, batteries can crap out any time they want to. If yours has a pro-rated warranty, that should pick up a good chunk of the replacement cost. I forget who makes therm but I have had good luck with NAPA's 84-month batteries.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-07-2017, 09:25 PM   #4
Husker
Husker's Avatar
Re: Which Battery..
I have it will not hold a charge, alternator charging at 14.6volts or so. Less than 1 ma amp draw dead. I have tried charging out of truck, Will not charge and shows approx 10 volts. So I am thinking it has a bad cell. I know I may have gotten a bad one but just thought I would get opinions from the best out there.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 08-07-2017, 09:40 PM   #5
bill3rail
bill3rail's Avatar
Re: Which Battery..
X3 on Gary's comment. What is wrong with your truck's electrical system?
Plus bring that one back to where you bought it and they may cover a replacement.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-07-2017, 09:54 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Which Battery..
Ron
Sure does sound like just a bad battery, probably nothing wrong with your truck. Good luck with the replacement, whatever you choose, and let us know how it works out.
- Mike -
RIP El Jay
Old 08-07-2017, 10:02 PM   #7
Warrens69GMC
Warrens69GMC's Avatar
Re: Which Battery..
Get a free battery, most decent batteries will have a free replacement warranty. Get the free battery and have it checked out before you take it home. Most batteries will show bad up to 6 months before they start giving you troubles.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 08-07-2017, 10:03 PM   #8
Husker
Husker's Avatar
Re: Which Battery..
Ro
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 08-08-2017, 02:16 AM   #9
toolboxchev
Re: Which Battery..
I realize they are not quite what they used to be yet I purchased an Optima Red Top over 1.5 years ago.
Still running strong, stock charging system. Next up was a Deka but I could not make it fit into my custom battery box.
If your charging system throws too many volts at a battery too fast it will certainly give the battery a short life. Trickle chargers do a 2 amp charge for that exact reason.
toolboxchev is offline   Reply With Quote
Old 08-08-2017, 08:57 AM   #10
Mollzyie
Mollzyie's Avatar
Re: Which Battery..
X2 on the red top ... yellow top is good too but red has more cold cranking amps . 👍🏼
M.A.G.A.
Mollzyie is offline   Reply With Quote
Old 08-08-2017, 09:10 AM   #11
Husker
Husker's Avatar
Re: Which Battery..
Toolbox and Mollzyie that's what I was needing recommendations to get an Idea what others have had luck with.
Truck is not problem battery is was. Thanks
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 08-08-2017, 09:30 AM   #12
Mollzyie
Mollzyie's Avatar
Re: Which Battery..
👍🏼 .... you do need an AGM charger or a charger that can charge AGM as well ... I make sure to maintain my battery cause I don't drive truck very often ... good luck ... look for promotion codes ... you can always find sales and promotion codes ! 👍🏼
M.A.G.A.
Old 08-08-2017, 09:30 AM   #13
67 chevelle
67 chevelle's Avatar
Re: Which Battery..
I like optima's , and odyssey
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 08-08-2017, 09:41 AM   #14
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Re: Which Battery..
I run Odyssey Battery - Dry Cell. Has lasted a few years no problems.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 08-08-2017, 10:40 AM   #15
68is4me
68is4me's Avatar
Re: Which Battery..
I like the old acdelco 78dt series have always had good luck with them and they just look good in old truck.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 08-08-2017, 12:36 PM   #16
ElKotze
ElKotze's Avatar
Re: Which Battery..
AC Delco's do look very nice. I'm running Optima Red's and Interstate, never had trouble with either one.
'64 C10 LWB, 283, 5speed
'68 C20 LWB, 327, 4speed
'69 C20 Custom Camper Longhorn, 350, 4speed
'72 C20 Cheyenne Super, 396, TH400
'66 C60, 292, 4speed
ElKotze is offline   Reply With Quote
Old 08-08-2017, 01:19 PM   #17
OregonNed
OregonNed's Avatar
Re: Which Battery..
My Optima Red has been awesome..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-08-2017, 08:46 PM   #18
garyd1961
Re: Which Battery..
You all may not believe this but we test 30 to 40 batteries a day where I work and the ones that test good most always are the NAPA Legend and Wal-Mart Max. They both usually test way above what they are rated at.
garyd1961 is offline   Reply With Quote
Old 08-09-2017, 11:41 AM   #19
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Re: Which Battery..
I have an Odyssey. And like you the first one crapped out on me within a couple months. They gave me a replacement with no hassle. Haven't had a problem since. I guess I just got a defective one the first time. But they stood behind their product.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 08-09-2017, 12:05 PM   #20
NGN
NGN's Avatar
Re: Which Battery..
My Interstate is doing good ,three years now and mostly a weekend driver if I'm lucky to have the time . Sits in the winter months more then a month a half and been starting on its own .If I recall not home right now the cranking amps are like 750.
NGN is offline   Reply With Quote
Old 08-09-2017, 01:12 PM   #21
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Which Battery..
Have good luck with WalMart batteries, currently running the MAXX 78S in my Silverado
Malo83 is offline   Reply With Quote
