Old 08-06-2017, 07:49 PM   #1
Dhaak64
Door sill plate material?
What are the door sill plates originally made out of on a 1964 c10? I see that the aftermarket has chrome-plated steel and stainless...
The PO painted mine, and I would like to clean them up and polish if they're stainless originally.
Thank you.
Dhaak64 is offline   Reply With Quote
Old 08-06-2017, 08:02 PM   #2
65chevysub
65chevysub's Avatar
Re: Door sill plate material?
I think they are steel I have stripped mine a couple of times, then they rust with any type of moisture, so I repaint mine
Hope this helps.
Here is one of mine, stripped and wire wheeled. I didn't paint them as I liked the lok of it being polished, but they got wet and started to rust but you can see the original material.
65chevysub is offline   Reply With Quote
Old 08-06-2017, 11:50 PM   #3
Captainfab
60-66 Nut
The original sill plates were just chromed steel.
Old 08-07-2017, 12:39 AM   #4
Dhaak64
Thank you guys.
Old 08-07-2017, 01:55 PM   #5
LVPhotos
LVPhotos's Avatar
Mine were plain steel, now chromed. If stainless they won't be magnetic. If in good shape have them chromed, litte more than aftermarket but real GM. Or they got chrome paint and powder coat.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-07-2017, 06:09 PM   #6
65chevysub
65chevysub's Avatar
Anyone here in Arizona priced getting the sill plates chromed? I would call Papago Plating, but I don't live in Phoenix and if they need to see them it's kind of hard to do
Old 08-07-2017, 11:48 PM   #7
Captainfab
60-66 Nut
If you could find an original set good enough to have plated, having them plated here in my area would likely cost $250-300.......that's no joke!
