Old 08-08-2017, 12:25 AM   #1
BOE
switch out carb on 64
have a 64 c10 with 292 engine. the carb is a one barrel rochester (or after market copy) never been to happy with it. anyone know of other carbs that bolt down to my manifold?
BOE is offline   Reply With Quote
Old 08-08-2017, 12:35 AM   #2
dracko
dracko's Avatar
Re: switch out carb on 64
I put a Holley/weber from langdons stovebolt on my 230. It was a great carb but I never did get the choke dialed in. Nice that it's a progressive 2 barrel so you can get decent mileage if you want to.
It did require a baseplate adapter that he also sells.
dracko is offline   Reply With Quote
Old 08-08-2017, 12:45 AM   #3
BOE
thanksDracko it looks a good site to find what i want
Old 08-08-2017, 04:06 PM   #4
Wrenchbender Ret
An early 80,s Rochester Monojet for a 292 is a good carb. It has electric choke. Or any 292 monojet with manual choke.
Wrenchbender Ret is offline   Reply With Quote
Old 08-08-2017, 04:20 PM   #5
Cris
Try Daytona Parts. They provided me with a reconditioned stock Rochester for my 63 and it works great.
Cris is offline   Reply With Quote
Old 08-08-2017, 05:40 PM   #6
Llay R. Rac
Llay R. Rac's Avatar
I just replaced my rochester B with a carter yf model # 4371. I found it on ebay.
I havent driven the truck yet but it does idle nice. yf is supposed to give better mileage.
i could get the rochester to run good for a while, then usually after one summer it would start to bog down and leak from the lid and need another rebuild, i got tired of that after 40 plus years of rebuilding it.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 08-11-2017, 12:25 PM   #7
vince1
I think the carb for the 292 if correct should have the same bore as the manifold at 1 5/8". 250's used a smaller bore carb at 1 9/16 on the same manifold.
We had a 292 in a 67 1 ton and I don't remember any carb problems. It burned lots of gas but then again it was a work truck with a heavy dump box. Lot's of torque in those engines.
vince1 is offline   Reply With Quote
Old 08-12-2017, 01:05 AM   #8
TJ's Chevy
TJ's Chevy's Avatar
Monojet or a 500 cfm holley 2 barrel with a 2 to 1 adapter will work nicely.
