04-13-2004, 01:15 PM | #1 |
9C1 axle swap for 5 lug swap
Has anyone ever used a 10 bolt axle out of a 9C1 Caprice on their truck before? I am planning on converting my '69 to five lug and was thinking of options on how to change the rear axle to 5 lug. I have seen axles for old cop cars pretty cheap, they have posi diff, they already have the 5 on 5 lug pattern, and rear disc brakes. I believe that they are a little narrower then my current axle but the saving of already having rear disc brakes and a posi diff I think is worth the work to install it in my rear coil spring truck. I have also heard that these axles are pretty strong so that shouldn't be anything to worry about in my half ton. Any one have an opinion on this?
04-13-2004, 10:18 PM | #2 |
Haven't heard of that swap....but keep us posted on the change...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
04-14-2004, 10:36 AM | #3 |
More Cowbell....
Plus, if it is a little narrower, then that leaves a little room for wider wheels/tires....or just a different offset.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
04-14-2004, 01:24 PM | #4 | |
Re: 9C1 axle swap for 5 lug swap
Nothing major but for me, a $350 eaton posi unit is much less of a challenge than a whole axle from a 9C1. I can point you to some websites and forums if you want to look further for a rear end. BTW the 9C1 rears are narrower than the civilian caprice and Impala SS units....Impala SS units are posi. In addition if you do find a 9C1 rear with posi...odds are it is probably worn and needs replacement.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection Last edited by miket; 04-14-2004 at 03:52 PM. |
04-14-2004, 03:36 PM | #5 |
Collector of Projects
The Impala SS came with a Posi 3.08 rear for the 94-96 production run. I have a 96 and if it ever stops raining I will measure it. I would love to have discs in the rear and this may work. ECE sells the saddles to convert for our trailing arms.
The only thing with the Impala/9C1 rear, I was told that the Posi units are not rebuildable. You would end up buying an aftermarket Posi when the OE fails so that you can rebuild as needed... Last edited by mcmlxix; 04-14-2004 at 03:39 PM. |
