08-09-2017, 01:36 AM | #1 |
Dually wheels
Does anyone know if the wheels off of a CUCV M1028a2 will fit my 87 two wheel drive dually? I don't know much about these heavier trucks so I don't know if the suspension/axles etc. is diffrent from the 4wd to the 2wd. Thanks in advance.
08-09-2017, 06:03 AM | #2 |
Next!
Re: Dually wheels
Yes they will. The m1028a2/3s had spacers so they could run 235/85 16s with out rubbing, unlike the stock 215/85 16s a regular dually would have had. Stock rims should be the same.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
08-09-2017, 09:32 AM | #3 |
Re: Dually wheels
Appreciate the help, GM72K10! Found a good deal on a full set now I can go ahead and buy them!
08-09-2017, 06:15 PM | #4 |
Re: Dually wheels
Huh? Mine has 235/85/16 with no spacers and not even close to rubbing. That is also the tire size that is on the door tag so those are stock size. 215's would be tiny.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
