250cid Choke to Carb Connection
Hi... The cable for my choke is not connected to my Rochester Monojet carb on my 250cid motor. Looks like I am missing the piece to connect it. Can someone please post a pic of how it should be connected? Thanks!
Re: 250cid Choke to Carb Connection
If the choke arm has a hole in it, the cable needs a Z bend on the end to slide it in.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Thanks bill3rail...
You are welcome.
Does the choke arm have a hole in it?
Yep... There's a hole in it. I was thinking the hole was for another piece that was missing. I'm assuming the end of the cable must have broken off.Thanks!
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
There is a cable attachment sold by Dorman that Autozone should carry.
The cable goes through the small hole and the screw goes through the bracket on the carb and threads into the attachment to hold the cable to the carb. This lets you attach the cable and it allows you to adjust the length.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#7 | |
