Old 08-11-2017, 10:00 AM   #5
Lugnutz65
Lugnutz65's Avatar
Re: Another power steering swap post
I used a 1974 GMC 1/2 ton PS box and the CaptainFab bracket. Worked out great. While making this upgrade, you should also consider installing a telescoping lower steering shaft. It's much safer. Since the PS box sits off the frame a bit further, there is a small change in the angle of the steering shaft. That can be corrected by using a U-joint. Here's my thread.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
