![]() Join Date: Dec 2003
Crossmember Removal
Is there an easy way to remove a 3 on the tree trans crossmember with the cab on the frame still???
https://www.ebay.com/itm/295742064443 |
![]() Join Date: Jun 2009
Re: Crossmember Removal
Cut it out is about the only way. Long metal cutting saw blade
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
It can be done by cutting the bolts as Larry said but be careful! I have a scar across my knuckle from trying to get my crossmember out while under the truck with the cab on. The edges of the member are really sharp.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
I was thinking this is the case... Hey, BTW, your truck is awesome and quite an inspiration for what i'm doing with mine. (I stalked you on IG and sent you a message)...
