Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-07-2017, 08:58 AM   #1
Project86
Ladder bar Q&A
Hey guys. I'm back again with some more questions. I've searched high and low and all over forums for some answers and guidance.
Here's where I'm at. Finally got through building a badass built 383 stroker. Around 545 to the crank.
I was wanting to do a full backhalf but time and money and resources she opted that out. So now I'm looking at ladder bar coilover
For anyone running bars, what length did you personally go with?
I was thinking 34-46" range?
As far as the front brackets, how many holes would be ideal for different settings?
I've read up a lot on instant center. Anti squat line and I know the ideal location for instant center is right at the anti squat line. So therefore does that mean a bracket with more mounting positions is more ideal??
I know the general rule of thumb when setting them up is o have the lower bars parallel to the ground at ride height.
Since I still have leaf springs I know it will be easier to mock up the ladder bars and cross member then once everything is square and fully welded, ree can remove the leaf springs.
So my questions
1. What length bars?
2. What pinion angle should be set before we weld?
3. How many mounting locations do your brackets have/would you recommend?
4. How to go about getting your suspension at or near anti swuat
Project86 is offline   Reply With Quote
Old 08-12-2017, 10:16 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Ladder bar Q&A
Really not a lot of info anyone can offer without knowing a TON of details about the chassis, weight, tire, gear, RWHP, and about a 1000 other details.
All I'll say is a quote from Dave Morgan's book 'Door slammers'
Misery loves a lot of holes in a chassis bracket
You cant tune the suspension if you build in no options. What's the 'right' set up for your particular combination,,, I dont think anyone can answer that. One thng to consider is there are some pretty quick guys here running the stock trailing arm configuration (with modified trailing arms and coilovers mostly)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-12-2017, 11:40 AM   #3
Project86
I honestly forgot to mention and go into detail about my setups.
As far as chassis. It's stock frame and front cross member. Future palms down the road is to do a back half subframe.
As of now I just have a leaf spring setup. I'm going with a pro street look. So I will be getting some 15x15 weld prostars for the rear with a 32" tall tire.
Weight of the truck I would estimate at 4100 with me in it. Have yet to scale it as I'm still in the building stages.
Rear end is a 10 bolt. Which I actually plan on building with 33 spline axles. Spool and maybe a 4.56 or steeper gear.
It will see very limited street use and occasionally maybe twice a month trip to my local track
Old 08-12-2017, 07:51 PM   #4
djracer
djracer's Avatar
Re: Ladder bar Q&A
Do a trailing arm conversion.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-12-2017, 09:16 PM   #5
Project86
I would actually prefer to do the ladder bars for now. As in the future I am going back half with 4 link and a big block
Old 08-13-2017, 10:21 AM   #6
djracer
djracer's Avatar
Re: Ladder bar Q&A
ladder bars are ok for a car but traing arms work well. i am looking to go 7's in the 1/4 with trailng arms!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-18-2017, 07:58 PM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Ladder bar Q&A
I just bought another Luv truck . I will be going big tire ladder bar . I have the C2005 Comp eng double adjustable set up .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 08-21-2017, 04:48 PM   #8
Super73
Super73's Avatar
Re: Ladder bar Q&A
Man.. Your Luv for Luv's is amazing how many is that now? I guess I need to buy one now if I ever want to own one as they might all end up at your place before we know it
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-21-2017, 05:37 PM   #9
Marv D
Marv D's Avatar
Re: Ladder bar Q&A
Yeah,,, but Hotrod can stop any time he want to
(rolls eyes!)
Old 08-22-2017, 09:35 PM   #10
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Ladder bar Q&A
This one fell in my lap for cheap . I have 3 .
(rolls eyes!)
This truck was priced right and an easy part out to double my money . It came with the C3005 double adjustable ladders and the multi position front crossmember .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
