Old 08-12-2017, 08:27 PM   #1
iowaboynca
iowaboynca's Avatar
Re: Hummer Seats
I like the integrated seatbealts on the hummer seats myself...one less thing to deal with. How tore up is the base of the SS seat on the left?
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 08-14-2017, 11:05 AM   #2
mobileortho
mobileortho's Avatar
Re: Hummer Seats
So do I.
Originally Posted by dsraven View Post
the taller the seat the further forward it will have to lean because it will hit the back wall of the cab. I have seen some where the driver almost has to lean forward when the seat is back far enough to accommodate leg length.
That's kinda what I'm running into now, I'm using some out of a Silverado that's similar to the Hummer. I'm 6'5" and in order to maximize the leg room It does hit the back of the cab and leans forward a bit. This whole swap started when I decided to add more insulation to the cab because it was getting too hot inside. I figured I'd change the seats, carpet, swap the floor shift to a column shift and the list goes on. I guess I can't leave well enough alone!
I'm trying to meet up with the seller of the SS seats to do some measuring. I also did a search here and saw where certain Nissan seats work well.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
