Closed Thread
Old 08-08-2017, 07:37 AM   #5676
colgad
colgad's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by mike16 View Post
I just installed a Pair of left and right side rear view mirrors on my 72 C-10 I was soooo frustrated I had to walk away. after a while, I just stopped working on them about every 30 minutes and took a break whether I needed it or not OMG! the passenger side took about 3 hours to do, the drivers side only about an hour.
Now I know why the big west coast mirrors and californication mirrors are installed from the dealer. real easy to drill out a small hole then chase it with self tapping sheet metal screws
my recommendation if you go with the factory standard mirrors on your 72 is to get a second set of hands to hold the inner reinforcing plate while you start the self tapping screws. Smaller hands are better because they can reach into a tighter place to hold that reinforcing plate from the few small access holes on the inside of the doors and when that plate is dropped inside the door, 10-15 times, a small hand and arm can reach deeper into the door to retrieve the plate and those very valuable factory sheet metal screws. and happy meals are cheap. You will know what I'm taking about when you get there. don't leave a broom handle or coat hangar inside the door as you will have to remove the door panel to retrieve it (them)when you begin the other door. Small hands will eliminate the need to use a coat hangar or broom handle to begin with.
The screws that come with the new repro mirrors are junk, some sort of stainless drywall screws. WTF? for 40 bucks each you think they would do the right thing with the correct screws, the rest of the mirror is pretty good, why go cheap on 40 cents worth of screws.
So.... keep your old fasteners as they are better, used, then the others are new. If you dont have an old set of screws, wait until you find a set of 8, 6 plus two spares. I'm betting on Corvette vendors for a set of the good quality correct screws. wait to get them rather than go through heck twice. The old used screws are a ferritic stainless steel so they too can be retrieved with a magnet.
You will also need that funny tool to remove the inside door handles, and it might be a good idea to get a few, 4 , extra door handle clips as those clips seem to fly off in every direction when you remove them.
It looks nice when done, I got my mirrors from Chevy Duty or what ever its called now. I like them a little more every day I walk past them but Damn it there was no love for about a whole day after the job was done. get some extra little hands to help out, Think happy meal.
the mirrors are very tightly mounted to the bracket.....for a good reason and should not be casually adjusted to accomodate various drivers. Mount them, adjust them and warn others NOT to adjust them further, as they may become loose and flop around. Also they are tight for a reason and should not be lubed to facilitate initial adjustment or they will eventually become loose again and flop around.
I dont think you will want to go through the routine(?) of doing these mirrors twice or more so take my advice
After all that work we need a photo or two
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 08-12-2017, 05:55 PM   #5677
jethro5333
finishing up the swap from the three on the tree to a 700R4. installed the shortened driveshaft and finished the Lokar shifter installation. just have to hook the exhaust back up, add fluid, and give it a try. (might be next week though.) doing this by yourself is a pain.
Sunday: tried to fill trans with fluid. no luck. new dipstick tube is so small I don't have a funnel to fit it. tried rigging something with a small tube but that didn't work either. gave up and ordered a stock style tube.
jethro5333 is offline
Old 08-13-2017, 02:31 AM   #5678
KQQL IT
At the body shop.
KQQL IT's Avatar
Cap and rotor.
Amazing improvement.
KQQL IT is offline
Old 08-13-2017, 10:18 AM   #5679
Quikshft
Quikshft's Avatar
After my last pull over to the coast I was a little disappointed with the output of my 350, so I'm working on a cam, header and Vortec head installation. Always had big blocks in my tow vehicles but thought I'd try an upgrade on the existing engine before going that route.
Quikshft is offline
Old 08-14-2017, 01:46 PM   #5680
Big Block
Big Block
Big Block's Avatar
Installed new grill and front bumper.
Big Block is offline
Old 08-14-2017, 03:26 PM   #5681
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Got my ammeter working after being dead for who knows how many years. Thanks to a board search, I checked the two fuses at the ends of the core support. One of them was shattered. NAPA didn't have any short 4 amp fuses so I'm trying a 3 amp. So far, so good.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline
Old 08-17-2017, 08:22 AM   #5682
jethro5333
finally got a transmission dipstick tube to go in the 700r4. bought a Mr. gasket tube but it didn't fit. ended up bending it almost straight to get it in. filled the trans and tried the gears (on jackstands). seems to shift OK. this weekend will be the big test!
Old 08-17-2017, 09:54 AM   #5683
el_fantasma
el_fantasma's Avatar
Originally Posted by Big Block View Post
Instead new grill and front bumper.
Love that color blue on our trucks
72 White Cheyenne, The Ghost
el_fantasma is offline
Old 08-17-2017, 10:54 AM   #5684
Big Block
Big Block
Big Block's Avatar
Thanks el fantasma, One of my favorites too. The truck was originally dark blue. One driver quality repaint about 20 years ago. Still looks pretty good.
Old 08-17-2017, 07:16 PM   #5685
silverstreak
I walked past it in the back yard wishing I had tine to work on it. lol
silverstreak is offline
Old 08-17-2017, 08:56 PM   #5686
paul blair
Finished installing new water pump, valve cover gaskets, gates belts after some fresh paint dried. Took more time than I first thought, one thing led to another, you all what know I mean. Turned out ok--no leaks--AHH the smell of fresh paint! This Forum and the people here are the Best! ( the florescent light sure does change the color of the paint )
paul blair is offline
Old 08-17-2017, 10:28 PM   #5687
VWNate1
VWNate1's Avatar
Angry Re: What did you do to your truck today? Chapter II
Looking *VERY* good ! .
I like the clean and simple uncluttered lines of this engine .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-18-2017, 08:36 AM   #5688
paul blair
Thanks VWNate1 I am still amazed with this forum and internet and how easy it is to share with others. I learn so much here and gives me something to look forward each day and my mental and physical health is better because of it! Good to hear from the West Coast. Happy Trails
Old 08-18-2017, 09:09 AM   #5689
Big Block
Big Block
Big Block's Avatar
Nicely detailed.
Old 08-18-2017, 09:10 AM   #5690
Big Block
Big Block
Big Block's Avatar
Nicely detailed. Looks good.
Old 08-18-2017, 01:35 PM   #5691
paul blair
Thanks Big Block-I see in your profile you have a Blazer-NICE-Question I am helping a friend with a 70 Blazer-he wants new long tube Exhaust Headers . Just wondering if your Blazer has long tube Headers, if so do they fix without modifying. 350-350-4x4 auto. I see HOOKER #2452-1HKR fit rear wheel drive but doesn't say 4x4 any information would be great.
Old 08-18-2017, 02:14 PM   #5692
Big Block
Big Block
Big Block's Avatar
Sorry, I can't help with that. Mine is bone stock expect for rally wheels and tires.
Old 08-18-2017, 04:13 PM   #5693
kenn
All most a year of sitting after a rebuild, I got it to start.
kenn is offline
Old 08-18-2017, 06:39 PM   #5694
toolboxchev
Trying to wax and polish an 84 Jeep for the wife. The bird crap will not budge even with a light polishing compound.
I am finishing up with a coat of wax and selling this junk.
Time to turn the efforts back the CHEVROLET!
toolboxchev is offline
Old 08-18-2017, 07:17 PM   #5695
74baggedbug
http://67-72chevytrucks.com/vboard/a...1&d=1503098181
Got these in the mail today now time to install once the sun goes down
74baggedbug is offline
Old 08-18-2017, 10:29 PM   #5696
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Welcome .
I was born in Brocton, Ma .
-Nate
-Nate
Geezer
VWNate1 is offline
Old 08-18-2017, 11:12 PM   #5697
dflarsen77
Active Member
My new summit heads came last week, so today I masked up my block, heads, and oil pan, shot with VHT primer and then chevy orange rattle cans. Looks decent. Definitely better than it did! I don't remember why I wanted to paint it while it was disassembled, but there was a reason. But I can finally assemble, and move on to suspension, brakes, bodywork, interior, trans conversion. Crap...
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline
Old 08-18-2017, 11:54 PM   #5698
SoCoC10
SoCoC10's Avatar
Installed the interior including the ACC carpet kit that I've had for 18 months!! Thanks paint jail! Belts and sill plates went in today too. Time to put a few miles on her to tie up any loose ends and get any bugs out.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 08-19-2017, 07:28 AM   #5699
BugzC10
BugzC10's Avatar
Ok...I give up, what are they?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 08-19-2017, 08:08 AM   #5700
Boog
laying low
Boog's Avatar
Good morning. I believe those are tail gate trunions.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Closed Thread
