Old 08-14-2017, 10:57 AM   #1
WilliamFd55
New LED fog lights, OEM look.
Hello all,
Wanted to install new LED fog lights on my 70' C10, but wanted to keep the stock look. If you are looking to do the same, here is what I came up with.... Took a 72' bumper, removed all existing hardware. Fabbed up some brackets and used the upper existing holes with some spacers to remount new lens. The LEDs can either run amber for cruising or bright white, to help out on the way home at night. I also made a lower front valance ( All metal ), to lower the appearance. Thanks for checking it out.
WilliamFd55 is offline   Reply With Quote
Old 08-14-2017, 12:45 PM   #2
bill3rail
bill3rail's Avatar
Re: New LED fog lights, OEM look.
Looks sharp, you can supply artificial light to a blackout area with those on white!
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-14-2017, 12:55 PM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
So you have a stock clear plastic lens in front of an LED lamp?
Too cool.
Old 08-14-2017, 01:10 PM   #4
68Stepbed
68Stepbed's Avatar
Awesome idea!! I like the valance also. How did you make it, and how does it attach?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-14-2017, 01:27 PM   #5
greasemonkey
greasemonkey's Avatar
Great idea and execution. I have trouble seeing at night due to new cars and their bright shimmering headlights, so this would help out immensely. Nice job on the valance too.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 08-14-2017, 02:02 PM   #6
WilliamFd55
Too cool.
Yes, clear OEM lens ( Ebay ). I had to shave them down a touch.
Old 08-14-2017, 02:11 PM   #7
WilliamFd55
Thank you, used flat stock steel. Made a jig out of wood to mimic the curves around the plate bump out. Welded directly to the bumper.
