Old 04-13-2004, 03:10 PM   #26
griesel72
griesel72's Avatar
here's mine
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 04-13-2004, 05:34 PM   #27
Faster_than_you
vdo gauges
I dont recall anyone using vdo gauges, maybe I didnt look hard enough. what are peoples thoughts on them?
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 04-13-2004, 05:38 PM   #28
Yukon Jack
Yukon Jack's Avatar
Here's the one for my 69, it's not a custom bezel, just the stock one reworked.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-13-2004, 05:52 PM   #29
67chev
67chev's Avatar
instrument cluster
This is what I have to go in my '67. Comes in three colors: blue, green, and teal. Also, I know they have the wiring harness for the 67 to make an easy switch, may have it for other years as well. Hope this helps!!
Tried a couple times to insert pic...can't get it to work...email or pm and I will send pic. This is a fully digital dash...looks nice, but definitely not stock![IMG][/IMG]
67chev is offline   Reply With Quote
Old 04-13-2004, 06:19 PM   #30
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
LOST WAGES, CAN YOU GET THE SURROUND PAINTABLE ???
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-13-2004, 06:20 PM   #31
gr8scott51
gr8scott51's Avatar
Highly recommended
If you put in a custom gage set, I highly recommend the use of a universal gage wiring harness. It allows you to install the gages in the insert on the work bench and then plug it in to your underdash wiring harness. I bought the Painless version.
scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 04-14-2004, 01:39 AM   #32
lost wages
lost wages's Avatar
i agree with gr8scott51, i used the painless harness for the gauges and it was real easy to wire them up. The only way the flaming river gauge panel comes is polished or non polished, i think it was around 180 dollars polished.
lost wages is offline   Reply With Quote
Old 04-14-2004, 03:22 AM   #33
bagged69chevy
I have a custom guage cluster and glove box door and Am trying to sell both. This is a fully functional Gauge cluster and Glove box door off of a 69 Chevy Pickup, all gauges are in excellent working condition. They are both Equipped with Billet inserts. These inserts alone go for over $150. The Gauge Needles are painted a red for an added custom touch. Both Pieces are in Excellent condition. If you interested.. Please let me know..
bagged69chevy is offline   Reply With Quote
Old 04-14-2004, 03:23 AM   #34
bagged69chevy
glove box door: If you want to see any more pictures, let me know, i can E-mail them to you in better quality
Old 04-14-2004, 09:53 AM   #35
Lobo'74
Lobo'74's Avatar
Here's mine
New SunPro oil, temp, vacum, and volt gauges. I'm going to go with the white MPH and gas gauges, get a white face SunPro tach - same exact model as I have, just white face, and put in into the center slot.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 04-14-2004, 10:04 AM   #36
Lobo'74
Lobo'74's Avatar
right side
right side
"Truck"
'67 small window
Old 04-14-2004, 02:00 PM   #37
miket
miket's Avatar
Re: Highly recommended
scott
Scott, what did the harness cost?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 04-14-2004, 02:08 PM   #38
gr8scott51
gr8scott51's Avatar
30 or 40 bucks. Available thru Summit or the Painless website.
Old 04-14-2004, 09:25 PM   #39
roj2323
Ok well I think I may have figured out what I’m going to do. I'm thinking about cutting up an old glove box door so that it fits the shape and size of the gauge opening then modify it a little more until I reach the desired look. I have basically come to this conclusion since nothing that is currently out there is what I want. I also want the opportunity to make something custom for my truck and this is the perfect opportunity. Thank you to those who have helped so far. It is greatly appreciated and a huge help.
I do have one last question.
Where can I find a set of gauges with the following criteria?
-white backing
-large gas gauge
-large Speedo
-small oil
-small temp
-small volts
-small time analog preferred
roj2323 is offline   Reply With Quote
Old 04-14-2004, 09:39 PM   #40
Lobo'74
Lobo'74's Avatar
White Gauges
SunPro has white gauges that blend in well (IMHO). The font even matches the original font in my '67.
try: http://www.actron.com/cgi-bin/web_st...id=606637_7343
and: http://www.actron.com/cgi-bin/web_st...id=606637_7343
autometer is another popular brand, and it has white faced gauges as well.
"Truck"
'67 small window
Old 04-14-2004, 10:08 PM   #41
guitarornothin
RUNN over AGAIN!!!
guitarornothin's Avatar
i like those sunpro ones but NOT white
67-72 TRUCKS ROCK
70 SWB shaved and a 72 front clip.and a poly tank.
Peep mirrors and a BIG BLOCK 468 in the making.
XNXNXNXNXNXNXNXNXNXNX
,/. EMAIL ME HERE!, Dont pm me please
guitarornothin is offline   Reply With Quote
Old 04-14-2004, 10:33 PM   #42
roj2323
Where did you get your guages from? Also is the clock a custom made guage or did you buy that as well?
thanks,
ondrew
Old 04-14-2004, 10:53 PM   #43
roj2323
found my anser n this thread: http://67-72chevytrucks.com/vboard/s...threadid=82578
thanks Yukon Jack for posting your pics and info
Old 04-14-2004, 11:46 PM   #44
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally posted by lost wages
another
Please stop posting pics of your truck. I can't stay focused on my Blazer as it is. Your not helping me at all....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
