Old 08-15-2017, 08:00 PM   #26
my56chevytruck
my56chevytruck's Avatar
Re: New here, loaded question
some of those CL listings I'd most definitely shy away from. I would want to buy a running truck to begin with and like so many others stated, look around a lot. you'll start seeing where the common problems are.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 08-17-2017, 09:37 PM   #27
e015475
e015475's Avatar
My perspective is the same as most here. Buy the most rust-free truck you can find, but I'll add some dollar values based on recent experience.
Almost any complete AD truck is worth $1500 to $2000.
To replace cab corners, bottom of the a pillars, door bottoms, floorboards and straighten out the sheet metal to primer at the going hourly labor rate today is $8-10k.
So to have a solid foundation to do what you want with the drive train and other stuff is going to cost you between $10 and $12K
If I were to do it all over again, I'd look for trucks less than $10K with as perfect sheet metal as I could find. This is for a truck you'd do with a good paint job.
If you want to go the patina route and all you want is rust free but not dent free I'd lower the max amount to about $6K
Just my two cents
e015475 is offline   Reply With Quote
Old 08-18-2017, 08:24 AM   #28
pvienneau
pvienneau's Avatar
+1 what e015475 said.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
