08-06-2017, 11:35 AM | #1 |
Knock sensor problems
72k10 with an LQ4 swap
Getting PO327 and PO332 Downloaded the troubleshooting guide And checked the following: Sensors to ground ohms out to spec (99.9 and 100.7) Wiring from sensors to PCM checks out AC voltage test is good right to connector on PCM Next step is replacing the PCM Anything I missed? Thanks
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
08-06-2017, 02:15 PM | #2 |
Re: Knock sensor problems
Replace both sensors and harness
08-06-2017, 02:26 PM | #3 |
Sensors And harness are new..
08-06-2017, 02:32 PM | #4 |
Then could be pcm problem
08-06-2017, 08:14 PM | #5 |
Have you had it tuned, or is everything stock in the engine and tune?
08-07-2017, 12:55 AM | #6 |
meowMEOWmeowMEOW
How many times has it triggered? Like if you clear the codes, do you get any period of function before the light pops up?
If you can watch live data, look at what the KR* count actually is, and see where the histograms show the hits counting. If you have a physical interference (things like transfer case, exhaust, trans xmember) touching/vibrating against the motor, it can actually trigger a large single hit of knock. It would show up on the logs as a spike, instead of a plateau like an actual knock condition would. Even easier....can you hear an actual knock? Because your getting BOTH sensors to trigger the same conditional code, it means there is either; a problem with the hardware (loose pigtail, partially shorted wire that only contacts under certain conditions), a kr threshold set oddly (unlikely unless tuner got ambitious, or sloppy), or an actual knock severe enough and frequent enough to trigger both sensors at the same time under the same circumstance. The only time replacing the PCM is a logical step is when there is an actual internal board failure, driver failure, component mismatch..or pissing off my tuner. If you think the PCM could be a cause, then try hard grounding the case. Probably best to check your grounding straps on the head and block as well, or consider adding some if you've streamlined the factory layout.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
08-07-2017, 03:13 AM | #7 | |
I can't hear a knock or detonation but exhaust is loud..and I am slightly deaf.. I have added additional alligator clip grounds to PCM case and block.. Because the truck is a 4x4 and runs 35's it can be a rough ride over some bumps...I did disconnect the PCM this morning when I checked wiring so maybe the connection wasn't good? I read somewhere that plug gap could cause the KS to trigger? Just got truck on road so we will see this week.
08-07-2017, 05:45 PM | #8 |
don't go cheap with sensors and senders. I have learned multiple times already with my ls swap, temp, oil, crank and knock sensors. don't get the cheap stuff, you will have to replace shortly after!!
08-08-2017, 12:21 AM | #9 |
meowMEOWmeowMEOW
^ very true when it comes to knock, cam, and crank sensors especially.
If you baby the truck, can you go farther? Does it seem like there is a certain situation in which it will always happen? Again, live data from a scanner or HPT would tell you if its "real" knock or not. Whats the story on the motor? If there was a ton of blowby, or something like assembly lube from break-in, its possible even new sensors can get fouled out.
08-08-2017, 10:13 AM | #10 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-08-2017, 10:36 AM | #11 |
i repalced the knocks in my 02 suburban didnt make it 200 miles kight back on i pulled the pos advance bwd sensors out and used ac delo and a dorman harness light never came back
08-08-2017, 11:16 AM | #12 |
meowMEOWmeowMEOW
Midnight, after a friends 3 day wedding weekend. I havent slept in about 50 hours. Time for bed.
08-12-2017, 12:26 AM | #13 |
Ok still having knock sensor issues..
I moved my OBD port into the cab so I can watch live data while driving. The one thing that I noticed is the vehicle speed says 0mph... I installed a Dakota Digital SEN-01-4L60 AND A SGI-5E speed sensor to cure a missfire I had (haven't had a misfire since)..should the speed data that the DD is giving the PCM show up on my Bosch 1100 reader? Or do I have an issue with the vehicle speed setup.
08-16-2017, 07:26 PM | #14 |
are the knock sensors torqued to spec?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
08-16-2017, 07:33 PM | #15 |
No they are not...I am going to re-torque to 15ft pounds this weekend. I know they are much tighter than that.
08-17-2017, 11:10 AM | #16 |
The torque spec is so you don't over tighten them. They can be damaged by doing so. If they are damaged then re-torquing them wont help.
08-17-2017, 11:41 AM | #17 |
I'll replace them with GM sensors...live and learn
08-18-2017, 12:54 AM | #18 |
Changed out the sensors for GM sensors...my Son's an apprentice Tech and gets parts at dealer cost..unfortunately he works for a VW dealership...they were $90.00 each (CDN) holy crap. Well hopefully it's the fix. Torqued to 15ft Lbs..we'll see tomorrow.
08-18-2017, 07:27 AM | #19 |
I feel the parts cost hurt. I actually was just going to tell you to check amazon.ca
I got delphi knock sensors for $57.73 each and free shipping.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-18-2017, 04:01 PM | #20 |
I saw those but wanted to get it fixed as I am travelling next week. I only live 9 miles from the border and have a US PO box too...most if not all my parts come from the US. Good news is the problem is gone! Drove 80-90 miles today and no check engine light...Thanks to all for your help!
