#22 |
Old member
The 67 SS Chevelle wheel I used bondo the cracks where not that bad. The wood and the 64 Impala wheel I used what is in the picture. You have to cut off just enough to work with because it will harden up pretty fast on you. Keeping it wet helps though. That's why I didn't worry aboy excess I just ground it off after it dries good.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
| Bookmarks |
| Tags |
| restore, steering wheel |
