Old 08-19-2017, 05:13 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Condition of these rear brakes?
This is a ground up restoration on a 71 C-10. I've never done a rear brake job, but I'll pull the rear brakes today.
Question is, from your observation, should I replace these parts? There is no visual damage, including the well of the brake drums. The rear brakes were replaced some time ago, but since then I'm guessing there's just 3-4K miles on this truck. Maybe I just answered my own question, but still interested in opinions.
From my angle, just clean what I've got & maybe paint the drums.
Thank you
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-19-2017, 05:56 PM   #2
71CHEVYSHORTBED402
Re: Condition of these rear brakes?
On another note, anyone aware of a parts diagram for the rear brakes on these Chevy's? I see some on the web for "typical" and other vehicles. If not, I may make one myself....................just as soon as I've identified all the parts (yikes).
Tony
Old 08-19-2017, 05:57 PM   #3
meenaggie
Looks like you have plenty of shoe material left. Inspect the cylinder for leaks. Inspect the rubber hose for cracks or other wear. If those look good I say leave them as-is for now based on the pictures.
meenaggie is offline   Reply With Quote
Old 08-19-2017, 08:04 PM   #4
PGSigns
PGSigns's Avatar
That picture you took is better than a drawing of the brakes. What you have looks fine. I would also recommend the checks above and run em.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-21-2017, 02:15 AM   #5
andrewmp6
Yeah like said if no wheel cylinders and axle seals are leaking id leave them alone everything looks almost new to me.
Old 08-21-2017, 08:50 AM   #6
sweetk30
sweetk30's Avatar
need a head on view of the brakes that hit the drum face . how close to the rivets or cracking .
right side pic is missing the adjuster arm push up spring . and lower hold together spring looks to be out of the hole . the one just above the adjuster.
diagram = only do 1 side at a time . there a flip flop of each other .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
