van tilt column
what all is involved in installing a tilt steering column from a van. will all of the regular tranny linkages work with it? I've heard its exactly the same just a little bit shorter but i thought i would ask and see what everyone had to say. thanks, steve
'67 c10 350/th350 |
![]() Join Date: Apr 2003
check the FAQ's section. you will have to take the intermediate shaft off your old column, shorten it a couple of inches, change the wiring harness (or buy an adapter) and install
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
couldnt find it
'67 c10 350/th350 |
I got a very good "how to" off of GMC Paul's website. it walked you through exactly what you had to do, and had pictures.
Good luck David
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
thanks for the help guys
'67 c10 350/th350 |
its all about the +6 inches
highboy, since you have a 67, you'll need to locate another piece off of a 69 - 72 truck before you can do it.
In 67/68 the column was not a colapsable style, you have a solid shaft from your steering wheel to your gear box. In 69, they chainged that. You'll need the intermediate shaft off of a 69 - 72. |
I agree with that , you will need later intermediate shaft earlier ones don't collapse. the connector you willl find on the van probably , some trucks had them some diddn't . or you can buy new
