Old 08-21-2017, 08:35 PM   #1
Harleymike
box is off
Box is off. Frame and cross members look great
Harleymike is offline   Reply With Quote
Old 08-21-2017, 08:38 PM   #2
Harleymike
Re: box is off
As a side note. When i first looked at it I thought WTF. That centre crossmember that the drive shaft linkage thingy ( can't remember the name of it )is attached to is installed crooked from the factory. For a second I thought the thing was bent. LOL
Old 08-22-2017, 06:47 AM   #3
PGSigns
PGSigns's Avatar
Re: box is off
In that picture the entire truck looks out of square. All the cross members should be square with the frame except the one behind the rear axle. Is the drive shaft thingy the center support bearing?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-22-2017, 06:52 AM   #4
Harleymike
Re: box is off
Jimmy
Its all square, except the one behind the axle. I triple checked everything.
Cross ways, up and down etc. The picture is playing with the eye on this one.
Everything was with in 1/4 inch or less with my tape measurement. I figured 1/4 inch was executable for 51 year old frame.
But you got me wondering so I went out and remeasured again. No more than 5/8 diff. Just in the back part so maybe a very slight bend the one way.
The frame is going in to be straightened so they should be able to double check that and bend it back.
I have never dealt with a bent frame. I have been told its all repairable. Im hoping thats true.
Old 08-22-2017, 07:50 AM   #5
pimpston65
pimpston65's Avatar
Re: box is off
its just the picture angle. whats your plans for the overload springs???
pimpston65 is offline   Reply With Quote
Old 08-22-2017, 12:06 PM   #6
Harleymike
Re: box is off
Hadn't really thought of it. Why?
Old 08-22-2017, 12:38 PM   #7
pimpston65
pimpston65's Avatar
Re: box is off
its a nice piece that isnt on most trucks. i had a set a fews yrs back but never used them so i sold em.
Old 08-22-2017, 12:39 PM   #8
Harleymike
Re: box is off
ahh. Are they worth much. Would leaving them on benefit the traction of the truck. Stop it from squatting down.
Old 08-22-2017, 04:21 PM   #9
pimpston65
pimpston65's Avatar
Re: box is off
they are overload springs not traction.
Old 08-22-2017, 04:44 PM   #10
Harleymike
Re: box is off
I realize that. But they also stop the truck from squatting down. Thought they might help in that dept. somehow. I could be wrong.
Old 08-22-2017, 06:10 PM   #11
pimpston65
pimpston65's Avatar
Re: box is off
the only function that i know of they provide is extra load capacity as far as traction i havent heard of that being a normal fuction. they may provide traction if there is a heavy load causing the axle to be planted firmer, but i learn something everyday
Old 08-22-2017, 06:23 PM   #12
Harleymike
Re: box is off
ahhh ok. Makes sense.
Maybe i'll pull them off then. It won't be used to haul anything heavy ever again. What are they worth. Or are they even sellable.
Old 08-22-2017, 08:23 PM   #13
pimpston65
pimpston65's Avatar
Re: box is off
i bought mine off a forum member for say $150 plus maybe $100 to ship bout 3yrs ago well you can always put them up for sale and see...
Old 08-22-2017, 08:24 PM   #14
Harleymike
Re: box is off
OK thanks. I will probably sell them, as I don't really think I will need them. Don't plan on doing any hauling.
Why did you want them for your truck.
Old 08-22-2017, 10:00 PM   #15
pimpston65
pimpston65's Avatar
Re: box is off
i was on a original parts buying kick.
