What would happen if.....?
My power steering hasn't worked for awhile now and I have been doing it manually for some time. No fluid, no belt going to it. What would happen if I disconnected the lines where it goes into the steering shaft and just put a jumper in there? Just like a 8 inch piece of hose with the flare fittings on them and just go from one right to the other.
Posted via Mobile Device |
![]() Join Date: Aug 2004
Re: What would happen if.....?
I've done that before, no problems with it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Who Changed This?
![]() Join Date: Jan 2013
It'll steer just as hard as it does now, so if you're doing it now, it should be OK. I would recommend putting fluid in it, though, to keep things lubed.
Yes, definitely have some fluid in there. I recall the steering felt notchy with no fluid.
I have remover the power set up from a power steering box and it is measurably harder to turn than Non power steering box.
I suggest you either fix the power steering box which is better or convert completly to a non power steering set up which is simpler. each workes equally well and has equal merrit |
