Old 08-20-2017, 02:05 PM   #1
Zogbert
Zogbert's Avatar
clicking until clutch slightly depressed
'72 C10
250ci
3OTT
Just had the driveline serviced by a highly regarded transmission shop
- flywheel machined
- new pressure plate
- new clutch
- new u-joints
- new hanger bearing
- rebuilt rear end
Now has a clicking noise that corresponds with driveshaft RPM. In first gear faster than second; second faster than third, which leads me away from the speedo cable.
When I depress the clutch pedal as little as a half inch, the clicking stops completely. It will click at idle in neutral sometimes, but not always.
There's no vibration associated with the clicking. At this point, it's more of an annoyance.
Thanks in advance.
1972 Chevrolet C-10 "Ba-Lou"
Zogbert is offline   Reply With Quote
Old 08-20-2017, 09:49 PM   #2
chiefcfd
chiefcfd's Avatar
Re: clicking until clutch slightly depressed
Sounds like the throwout bearing. Was it replaced?
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 08-21-2017, 09:33 AM   #3
lilred2
lilred2's Avatar
Could be the wrong throwout bearing also but it sounds like the throwout bearing is probably to blame. I would take it back to the shop and have them look at it.
lilred2 is offline   Reply With Quote
Old 08-21-2017, 11:08 AM   #4
Zogbert
Zogbert's Avatar
Thanks. I'll give them a call.
Old 08-21-2017, 11:56 AM   #5
demian5
demian5's Avatar
Problem solved!
http://www.classiccarstereos.com/196...SABEgIeGfD_BwE
http://www.lmctruck.com/features/cb/...CABEgJuhvD_BwE
http://www.ebay.com/itm/like/1727764...=ps&dispItem=1
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-21-2017, 12:56 PM   #6
Zogbert
Zogbert's Avatar
Old 08-21-2017, 01:08 PM   #7
lilred2
lilred2's Avatar
Pilot bushing could also cause this.
Old 08-23-2017, 04:40 AM   #8
mike16
yep! sometimes those roller bearing pilot bearings can get damaged whether they are used or brand new when installing the transmission incorrectly.
bearings are overkill and in most cases a rebuild kit will include a new BUSHING and not a bearing for very good reason
mike16 is offline   Reply With Quote
Old 08-23-2017, 06:47 AM   #9
Killer Bee
Killer Bee's Avatar
clicking sound only or can you feel it in the clutch pedal, gear shifter, anywhere else?
proper clutch adjustment and freeplay?
proper release bearing for pressure plate type?
I was handed a diaphragm release bearing with a borg n beck pressure plate once in a 12" clutch setup..
more than clicked, clutch was nearly impossible to release but other similar scenarios may be the culprit..
either way sounds like a comeback and the garage owes you some rework..
good luck!
Old 08-23-2017, 09:33 PM   #10
AussieinNC
Moderator
AussieinNC's Avatar
1/ Worst case scenario from your description is the input shaft gear has a chipped tooth...they did put oil back in the tranny didnt they?
2/ The pressure plate release fingers are not all equal...one is a little higher than the rest...replace the pressure plate.
3/ It will not improve over time...it could point to a bad spring that could fail suddenly.
4/ Also, make sure the return spring is in place to pull the release bearing away from the fingers on the pressure plate.
AussieinNC is offline   Reply With Quote
clicking 3ott
