Old 08-23-2017, 09:46 PM   #11
gigamanx
Re: Francis the Tow Pig - 1949 GMC 250 Dually
Shop time last night produced some good results. I pulled the pan and removed the broken dipstick tube, replaced with a good used one I had in my stash. Then set to buttoning things back up, cleaning, and taping. I was able to get the block and heads, engine/tranny mounts all painted, and cleaned up the PS/Alt bracket and water pump to spray black.
I gotta ask how did you get that frame so squeaky clean before paint? I'm having a heck of a time with engine cleaner, wire brush, and brake cleaner. Can't seem to get it to a point I'd want to lay paint down on top. I'm definitely borrowing your radiator support mount idea. That looks great! Did you just weld it or bolt through the bottom of the frame too?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
