Old 08-16-2017, 09:51 PM   #2126
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Danny Boy is BAACK! w/ '55 Big Window
Its getting there!
ChuckDriver is offline   Reply With Quote
Old 08-16-2017, 10:52 PM   #2127
oldman3
oldman3's Avatar
Great pics, and truck is coming along.
oldman3 is offline   Reply With Quote
Old 08-16-2017, 10:59 PM   #2128
lower50's
lower50's's Avatar
Looks like a nice place. Bit by bit!! Question... will the coils get to hot down there?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 08-16-2017, 11:55 PM   #2129
Dan in Pasadena
Dan in Pasadena's Avatar
Nah, should be fine. They're ordinarily mounted ON the engine right above exhaust manifolds and heat rises. Down there they're a little below the manifolds but the manifolds will be Jet Hot coated and beyond the piping will be wrapped.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 08-17-2017, 04:02 PM   #2130
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-17-2017, 06:39 PM   #2131
Dan in Pasadena
Thanks Kim! What's the latest with your truck?
Stopped by the shop today to sort of "Show the flag" more than expecting to see much. A crossover radiator pipe has been fabbed from stainless steel and I'll polish it eventually. It will be installed with two very short hose sections. Of course no polish in the grip areas of the hose. It will run right behind and parallel to the fan guard. Still can't decide if I should paint or polish that? It might be body color red or powder coated gloss black or polished chrome-like. Oh well, to be determined.
I also ordered a small fuel pressure gauge for the driver side fuel rail. Better than a plain black plug. Site wont let me upload the pic of it, says I have the wrong file extension - whatever that means?
Old 08-17-2017, 07:36 PM   #2132
oldman3
oldman3's Avatar
Nice looking piece...Jim
Old 08-17-2017, 09:37 PM   #2133
ChuckDriver
Well done!
Old 08-18-2017, 04:42 AM   #2134
rapid49
rapid49's Avatar
Can you show more of what was done to the water pump? I am trying to figure out how I am going to do mine.
rapid49 is offline   Reply With Quote
Old 08-18-2017, 09:47 AM   #2135
Dan in Pasadena
I dont have a picture now but will take one and post later.
Basically the inlet was cut off because it pointed the wrong way and a replacement inlet was welded onto the pump pointing straight up. That allowed us to fabricate the pipe I show in the photo above. The reason for all this is the cross flow radiator I used has its top inlet on the driver side - opposite to where the water pump inlet originally pointed.
Old 08-18-2017, 11:08 AM   #2136
Russell Ashley
Russell Ashley's Avatar
Dan, I love your build and the direction you have gone with it so far, but wouldn't it have been easier and more convenient to just get a radiator with the correct configuration? That pipe is a nice piece of work but it looks like it is going to make it difficult to reach anything on the front of the engine.
Russell Ashley is offline   Reply With Quote
Old 08-18-2017, 11:15 AM   #2137
Dan in Pasadena
Thanks Russ,
Yes I suppose it would have been easier to have used a different radiator. I'm frankly not sure why this one was used.
EDIT: Ok, I asked. If the inlet and outlet are on one side the water runs down one side, doesn't flow THOUGH the core. Instead it takes the path of least resistance. It COULD have been done with a double or triple pass core but that would have added thickness I didn't need/want and necessitated using thin electric fans. I wanted the reliability of a mechanical fan.
Old 08-18-2017, 02:10 PM   #2138
joedoh
joedoh's Avatar
nice crossover pipe!
me too. its funny, when I see people talk about losing all those horses I wonder where they are driving at 10/10ths all day every day. electric fans use a LOT of current, and that comes from the.... help me out folks.... ALTERNATOR. which is belt driven! so I guess the way to save hp is to take off something that is driven from the belt and put on. something. that is... driven... by..
hmmm
Old 08-19-2017, 03:38 AM   #2139
Nut Case
Nut Case's Avatar
Danny
Just a thought make sure that a bead is rolled into the end of each pipe, for clamping behind.
Things are moving forward, great pics..
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 08-19-2017, 02:45 PM   #2140
Dan in Pasadena
Thanks NC, Yes Mike did that. It's not a big thing but I'm wondering if enough of the welds can be ground off so they won't be visible after polishing the pipe?
Old 08-20-2017, 01:04 AM   #2141
G&R's57GMC
G&R's57GMC's Avatar
Gee if you have to replace the water pump that could be a problem for a on the road repair.
I saw this a few years ago at a car show. I asked about cooling and what the set up was.
It's a 2001 Camero Rad and Fans . It cools great even in 105+ weather. This is what I'm using in my build but with rubber hose. Mine is a 5.3 van engine with cable throttle.
The Rad just drops in after clipping the lower inner strut on the core support.
The best part is it's way less $$ then the aftermarket .
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 08-20-2017, 12:08 PM   #2142
G&R's57GMC
G&R's57GMC's Avatar
I find that GM has a bunch of water pumps for the 5.3
These are pic of my water pump from a 2005 Chevy Van. This may save you trouble in the future .
Glen & Jane's Rides
Old 08-20-2017, 07:30 PM   #2143
Dan in Pasadena
I don't know if the WP from a 5.3 will fit a 6.0, I'd better find out!
Old 08-23-2017, 07:31 PM   #2144
Dan in Pasadena
I've seen too many episodes of Overhaulin' or Garage Squad. I guess I'm expecting my truck to go back together in 30 minutes! Lol.
- The Dakota Digital HDX & modules are installed. But that doesn't address that holes were drilled & threaded into the dash struts for each to mount them. The wiring also had to be trimmed and terminated properly.
- The steering column was FINALLY reassembled after the lost part was delivered. It looks great but is still not mounted to the dash so the wires for signal lights, etc can't be run/terminated.
- PS reservoir & radiator overflow tanks have been mounted on driver's side of core support.
- The ambient temperature sensor for the gauge is tiny and installed into the core support behind grill.
- I ordered a liquid filled fuel pressure gauge to use instead of a plug in driver side fuel rail; it's installed and looks good.
- Ordered but not installed are Cadillac CTS horns. Stock one is too big to easily hide. They're small and mostly plastic unfortunately but they're loud! These will be mounted in the wheel well when they arrive.
- Today the knock sensors were being installed in the valley cover.
It's all getting done but it just seems to be dragging.
Old 08-23-2017, 09:50 PM   #2145
gigamanx
I feel ya. I have been trying to get the engine and transmission back into my truck so I can move forward. Its amazing how many little holes, bolts, mounts, etc need to be figured out before the engine can go in. I still don't have the accessory placement figured out but I guess that can happen after the engine is back in its home. I've gone to the auto parts store everyday this week haha. I swear every time I go out there I'm staring at the same thing. The good news is, I've had plenty of time to clean the garage up while waiting for parts to arrive.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 08-23-2017, 09:58 PM   #2146
Dan in Pasadena
^^^ Thanks for the comments^^^
In my case the engine and trans had ALREADY been in the frame with the cab on and there was STILL problems with putting it all back together. But Mike keeps telling me, "Yeah, it's a '55 Chevy but it's still a custom built vehicle. Everything has to be fitted right for it to look right and perform right and that just takes time." I know he's right but damn!
Old 08-23-2017, 11:10 PM   #2147
Dan in Pasadena
Oh and just because we're all truck guys I'll post a couple pic's of an early C10 Mike had in his shop.
This is not a frame off job but it looks nice from 10 feet. Up close the paint prep was not done well enough. A prior paint job's chips were not feathered out and could be seen in a few places. In the wheel wells and frame its a little crusty but it looks good for a long bed stepside.
Old 08-24-2017, 04:21 PM   #2148
murd969
Your build is looking good.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 08-24-2017, 06:20 PM   #2149
lower50's
lower50's's Avatar
Yes it will seem like it's dragging, but before you know it you will have nothing else to do Keep up the good work.
1951 MG TD
Old 08-25-2017, 07:37 PM   #2150
Dan in Pasadena
Friday, August 25, 2017
Mike wanted to run a better looking cover weld bead over the what he originally did on the modified waterpump neck. Glad he's trying to make it look pefect but it just adds time. Pump pulley was re-sprayed black and pump re-installed. Upper & lower radiator hoses were finally installed - all looks good & well fitted.
Heater control valve was installed in passenger side wheel well.
Dealer says there's a back order on steam control port plugs - I guess they're called? I've posted a pic of them. We can start the engine without them since if there's no water in it. But we're waiting on new plug wires to arrive and the driveshaft to be fabricated. Guy is running behind on that.
Pleased with everything.
PS: Site won't let me upload the photos - says missing a "security token" - What's that/How to fix?
