08-22-2017, 09:29 PM | #1 |
Gauge Reading hot but its not.
Okay guys its Greenie again with the same issue. I bought a thermostat housing with a hole in it to put my temp. sensor in it. I bought a new temp sensor at Napa its a Proformer one its one for our year and its still making my gauge go nuts. I installed a new Edelbrock 750 (had a 600 performer) because I thought it might just be running lean and the shop that built my 383 recommended i step it up to a 750. My radiator cap that has a temp gauge in it says its at 150 along with the gun it shows 152 but my gauge just climbs up and up and up. I have a new aluminum radiator with cooling fans and it worked great along with my gauge with my stock motor. Please someone help me.
08-22-2017, 09:45 PM | #2 |
Moderator
Re: Gauge Reading hot but its not.
The new sender is most likely the wrong one...
Check the cross references at NAPA for an equivalent to 1993369 Also ACDelco G1852 is the correct replacement that seems to be readily available. Also, make sure the sender unit has a good earth contact to the housing...if the unit has a poor ground, it will read high...if you remove the wire and turn the ignition on, you will see the gauge go to Hot... |
08-22-2017, 10:00 PM | #3 |
Okay Aussie thanks. I will check and see if they have one of those. Im so frustrated with this thing. New motor and can't drive it until I get this figured out.
08-22-2017, 11:22 PM | #4 |
Your temp sensor won't be accurate on the downstream side of the thermostat.
You got pics of your motor? |
08-23-2017, 12:46 AM | #5 | |
Do you have a coolant overflow tank? 150 is an awfully low temperature for your engine to be running at. Where are you measuring the temperature with the gun at? I'm not familiar with a radiator cap for our trucks that have a temperature guage in it. How long of a probe does it have? Is it fully immersed in coolant?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 08-23-2017 at 12:56 AM. |
08-23-2017, 01:26 AM | #6 |
Try putting the sender in the head or in the intake
08-23-2017, 08:40 AM | #7 |
x2 doesn't belong in the thermostat housing. I also agree its a grounding issue as well.
08-23-2017, 09:09 AM | #8 |
Did you shoot the temp gun at the block , or thermostat housing ?
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
08-23-2017, 10:22 AM | #9 |
Who Changed This?
My gauge was all over the place, and a sender didn't help. It also wasn't actually running hot, like you are experiencing. I ended up putting in an aftermarket mechanical temperature gauge, and it's fine. It is either the printed circuit or the gauge itself, but I haven't dug into it, yet.
08-23-2017, 01:35 PM | #10 |
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
08-23-2017, 11:58 PM | #11 |
Today I placed my original sensor from my old stock motor (it registered normal with this motor) in the intake of my new motor and I have the same results, gauge just keeps rising. I think it has to be either the printed circuit or the gauge. I guess next on my list will be buying new gauge and circuit. I will try what HO455 said to do and see what I get. Thanks to all for your help.
08-24-2017, 12:04 AM | #12 |
I do have a coolant overlow HO455. The level pretty much stays the same in it. I bought and aftermarket rad. cap at Oreileys that has a temp gauge built in. I will just buy a better gauge. Do they have one with numbers that will working in the factory gauge cluster? Thanks HO455 you have been a big help. All you guys have been. This site has really been helpful. Thanks.
08-24-2017, 12:43 AM | #13 |
OK. That's good with a overflow tank the radiator stays full as does the upper hose. With the upper hose full of water then the common issues with using a sensor in the thermostat housing go away. It's how my Burban is set up. You can convert to an aftermarket guage in the bezel but it is not a simple bolt in affair. There are quite a few threads with ways to do it.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-24-2017, 07:26 AM | #14 |
Just for kicks, put a volt meter on your battery with the engine idling and watch it for a few minutes. My '70 had a bad voltage regulator that was allowing up to 17-18 vdc at the battery. I changed the regulator out and it cured several problems including a temp gauge that was reading hot. The longer it idled the higher the voltage got and the higher voltage caused the temp guage to read higher and higher. It also cured a problem with light bulbs burning out prematurely.
08-24-2017, 07:32 AM | #15 | |
08-24-2017, 10:37 AM | #16 | |
08-25-2017, 09:35 PM | #17 |
Okay guys update on the gauge reading hot. I read TBone1964 thread about placing the ground wire on the the back of the gauge cluster and it seems to have fixed my problem. I drove it further then I ever have with my new motor and just stayed on the normal mark. Hopefully this is a permanent fix (on my hands and knees praying right now). Thanks to all the members for your help. Much appreciated. If anyone else needs help with this just search "gauge cluster fix its the one by TBone1964.
08-26-2017, 06:48 AM | #18 |
Excellent work! Glad to hear this issue is behind you. Now go drive the wheels off it
