Old 08-27-2017, 09:04 PM   #1
mikewarme
Firewall Pictures
Hello Folks,
I am sending my 69 cab out for sand blasting than to body. I am trying to figure out which small screw holes are factory and which are not. This is mainly in the master cylinder area. My truck is a factory a/c truck so if you have a clean firewall you can share pics of this would help. I know the screws for the wire gutter , and column support etc. I know somewhere the screw head sticks out for the horn relay......... Perfect time to show off your firewall!
mikewarme is offline   Reply With Quote
Old 08-27-2017, 09:34 PM   #2
nds1968
nds1968's Avatar
Re: Firewall Pictures
Does this help
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 08-27-2017, 10:30 PM   #3
72_swb
72_swb's Avatar
Have them shave it all lol. I worked mine to where the body lines matched up on both sides. Looks like one solid piece. Ran painless wire harness that comes out behind the motor. No wires or mess.
72_swb is offline   Reply With Quote
Old 08-27-2017, 10:48 PM   #4
toomany2yz
Looks real nice till you get to the hose clamp on the steering column. Atleast turn it so the screw part is on the bottom/hidden.
toomany2yz is offline   Reply With Quote
Old 08-27-2017, 11:22 PM   #5
72_swb
72_swb's Avatar
Yeah I know. Working on that. Finally found an original one and installing next week. But hey. Thanks for pointing out the flaws. Only a 50 hours in that firewall. Where pic of yours toomany??? I bet I can find some flaws or are you in pieces��
Old 08-27-2017, 11:57 PM   #6
mikewarme
Originally Posted by nds1968 View Post
Does this help
Wow ! Thanks a lot ! I had forgotten about the ebrake holes....... I've found 2 very small holes from a self tapper that do not need to be there thanks to your help.
Old 08-28-2017, 12:02 AM   #7
mikewarme
Does this help
Since you are doing the same thing as me with regards to complete disassembly........how are you addressing the 48 year old seam sealer on the joints ? I've removed what I could as it as hard and a little rust was under . Was evident GM had no primer on the bare steel. From what I understand, and maybe Special-K has an idea....... joints were heated to 200 set to allow sealer to flow between joints. Curious what everybody has done here.
Old 08-28-2017, 12:57 PM   #8
Doug's68SS
here are a couple of mine, just sprayed it in Epoxy.
Doug's68SS is offline   Reply With Quote
Old 08-28-2017, 04:24 PM   #9
57larry
thank you guys for the firewall pics
57larry is offline   Reply With Quote
Old 08-28-2017, 09:52 PM   #10
nds1968
nds1968's Avatar
I already started to scrap it off. I'll finish scrapping then wire wheel or sand the area. Spray it with primer then apply seam sealer to all the seams.
Nate
