Closed Thread
Old 08-27-2017, 05:13 PM   #5726
In The Ten Ring
Re: What did you do to your truck today? Chapter II
I have spent the day cleaning up two of my "Custom 10" emblems. Paint stripper and Bar Keeper's Friend worked great on the one and Goo Gone is doing a fair job (slow though) on the other.
Apparently a previous owner used a caulk-like or silicon substance to help it adhere to his truck at some point.
In The Ten Ring is offline
Old 08-27-2017, 06:05 PM   #5727
VWNate1
VWNate1's Avatar
Exclamation Re: What did you do to your truck today? Chapter II
I'm amazed that the disc brake conversion is there .
I'm hoping to find a wrecked/rusted out Suburban with the larger drum brakes to put on my '69 C/10 but I'da prolly grabbed this disc bake kit the instant I saw it .
-Nate
Originally Posted by 66clow View Post
Picked up some honda civic door opening sills.$20 They are the perfect length. Will paint the gray area to match the interior i go with. Couldn't find black. Also saw what was left of this probably 68 in the yard.
VWNate1 is offline
Old 08-27-2017, 09:34 PM   #5728
ThePunisher67
today I ordered everything to Create my own Brake lines and Fuel lines I discovered 5 leaks in the lines I am going to be taking the cab and the bed off soon so might as well put in the rear gas tank and new lines.
ThePunisher67 is offline
Old 08-28-2017, 03:15 PM   #5729
'70_402
'70_402's Avatar
I drew up and water jet cut a piece of aluminum for my Speedhut gauges. I think it turned out pretty cool. just cut the old plastic out and riveted on the new panel. easy peasy.
'70_402 is offline
Old 08-28-2017, 07:04 PM   #5730
ThePunisher67
what did the Gauges cost you and do you have a link?
Old 08-28-2017, 07:30 PM   #5731
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
This E-brake hardware cleaned up nicely. Less the clips anyway. I'll have a pot of new nuts and washers to use, but somehow I end up cleaning up the old anyway.
Sure takes a while, but white vinegar & WD-40 hasn't failed me yet. I'll have these black zinc plated or phosphate coated.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 08-28-2017, 07:38 PM   #5732
'70_402
'70_402's Avatar
I don't have a link.. it's just the 4" gps speedo and 4" tach. the rest i think are 2-5/8".
Speedhut is the brand.
'70_402 is offline
Old 08-28-2017, 11:48 PM   #5733
In The Ten Ring
All I got done today was more cleaning up on a used fender emblem. Evaporust soak took off all the road grime the silicon caulk had trapped. I got nearly all the rust off it too, some seems trapped in the pores.
I want to do more caulk removal before injecting the nail polish.
Old 08-29-2017, 04:05 PM   #5734
OregonNed
OregonNed's Avatar
I just put on a set of Taylor cut-to-fit wires with Moroso wire looms, (was having issues with a few wires being too short and laying across the valve covers). Seemed to turn out good!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 08-29-2017, 04:17 PM   #5735
snj8198
snj8198's Avatar
Drove it. I've been having issues with the truck shutting down. Surprisingly, it is RPM noise from the MSD ignition box affecting the pickup wire for the FiTech efi system. I tore my wiring harness apart, separated the wiring between the efi and ignition and now it's running well again. Very interesting but frustrating too.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline
Old 08-29-2017, 04:27 PM   #5736
BugzC10
BugzC10's Avatar
Got the amp guage working...not real exciting. Bearly moves with the power turned on. Thinking about upgrading to the 76+ volt meter kit. Have to find out how extensive the modification is to the cluster.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 08-29-2017, 04:30 PM   #5737
BugzC10
BugzC10's Avatar
Did the same with Taylor wires
I how is the braking without power brakes?
BugzC10 is offline
Old 08-29-2017, 06:33 PM   #5738
OregonNed
OregonNed's Avatar
Not that bad. Takes some effort of course, but no problem stopping. I'm a little wary on these crazy freeways out here though.
Old 08-29-2017, 08:11 PM   #5739
In The Ten Ring
A little more cleaning on the emblem, more of the of the caulk came off. Just what's around one stud left now. It's back into Evaporust soak.
Old 08-29-2017, 09:37 PM   #5740
mud.man.rj
mud.man.rj's Avatar
snj8198, I tried to send you a message on the fitech unit but your in box is full
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 08-29-2017, 11:09 PM   #5741
VWNate1
VWNate1's Avatar
Post Drum Brakes
I added a stock power booster to my '69 SB, it really reducexd the pedal effort a lot .
Now, even SWMBO can drive it although she refuses to do so .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-30-2017, 05:12 PM   #5742
In The Ten Ring
Still cleaning the emblem and making great progress! Nearly all of the old caulk is off now, just a tiny bit left in a crevice.
Old 08-30-2017, 06:31 PM   #5743
RodnRudy
RodnRudy's Avatar
Not so much what I did to my truck as what I did for my truck. Just got done ordering a new AC Delco HEI distributor and a pair of United Pacific LED tail light assemblies. The old girl's a money pit but I love her just the same.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 08-30-2017, 07:08 PM   #5744
AussieinNC
Moderator
AussieinNC's Avatar
"The old girl's a money pit but I love her just the same..."
you are talking about your truck now ?
AussieinNC is offline
Old 08-30-2017, 07:42 PM   #5745
RodnRudy
RodnRudy's Avatar
Well of course. LOL
Phil
RodnRudy is offline
Old 08-30-2017, 09:23 PM   #5746
mud.man.rj
mud.man.rj's Avatar
How could you not?
5.0 4spd std.
7" lift w 35's.
Old 08-31-2017, 01:52 PM   #5747
JMD
JMD's Avatar
Replaced the useless brass float that came with my fuel level sending unit with a plastic float out of a Jeep CJ. The lack of quality control at these aftermarket manufacturers continues to amaze me.
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline
Old 08-31-2017, 03:03 PM   #5748
VWNate1
VWNate1's Avatar
Post Carby Floats
Interesting as modern plastic floats often get soggy with ethanol and sink .
Doesn't TOMCO (NAPA) still make good brass ones ? .
-Nate
Geezer
VWNate1 is offline
Old 08-31-2017, 07:39 PM   #5749
71CHEVYSHORTBED402
Among other things, I learned how to manually turn an engine. I pulled the plugs & gave the cylinders a shot of fog oil.............................Turning the crank pulley by hand is a real ball buster for this frame, but it works. However, this tool on the flex plate makes it super easy. Another board member recommended it. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Tony
Old 08-31-2017, 08:14 PM   #5750
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Carby Floats
I just bought a NAPA carb kit for my 72 with the original Q-Jetand it had the brass float and my friend doing the carb was surprised the float was brass..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Closed Thread
