Old 08-22-2017, 07:10 PM   #1
RANDY COX
RANDY COX's Avatar
Lockouts the good the bad
And the ugly, I'm getting ready to buy some lockouts for a Dana 44 1/2 ton
what's everyone running and what's the best brand to get, I bought some Mile Marker's yrs ago for a 90 Burb and they worker ok no issues. I kinda like the warn lockout's anyone tried them....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-22-2017, 10:59 PM   #2
sweetk30
sweetk30's Avatar
Re: Lockouts the good the bad
best and never look back = yukon . its a best design of old school spicers from both dana 44 style and dana 60 style . they took both sets and used the best parts of both in them to make there design . looks like 322ish on the auction sitE . . . and these also are the shortest stick out depth from the wheel hub .
and if they ever fail they do it LOCKED . . . most others fail OPEN
and my opinion of warn hubs these days is over priced crap . no real diffrence from std to prem inside them . and if fail there open = no 4x4 .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 08-22-2017, 11:44 PM   #3
'63GENIII
'63GENIII's Avatar
Got the Warn Premiums for the D44 3/4 ton axle I have. 160$ IIRC. FWIW, Ive blown up a few stock Spicers and a Warn Premium on D44s. Every time it was due to getting too aggressive and outside of the limits of the 44. Got lucky every time and didn't break an inner axle. Ive heard hub locks called "hub fuses". Could be the reason for the name. I like the idea of keeping parts that might break accessible (not inside the axle tube) and also carrying an old spare if I know I may need it.
For light wheeling and snow / ice covered roads, the 44 and even stock Spicers are fine. Warn Premiums are a little overkill but they sure top off a newly rebuilt axle nicely.
IMO If you're looking for super high quality, unbreakable hub locks - you should probably be buying them for a Dana 60.
I do agree that the retaining screws that hold the hub lock onto the hub left a poor impression on me so I replaced them with something that felt a little stronger. Other than that, theyve been solid all summer and Ive been using them quite a bit. We will see how they work this winter.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-23-2017, 07:45 AM   #4
Warn Premium hubs are as good as you'll ever need if you aren't out trying to break something. The cost is very reasonable for the quality you get. I have put these on a few trucks with no problems what so ever and never heard a bad rap on them. Never used Milemarker but never heard negative on them. There are also Superwinch hubs and from what I've seen and heard by others, those are also quality parts.
Old 08-23-2017, 08:40 PM   #5
RANDY COX
RANDY COX's Avatar
Thanks for the input guy's...
1964 BBC 402 4x4
Old 08-24-2017, 11:04 AM   #6
jeffahart
jeffahart's Avatar
The best: Yukon
What I'm running: warn standard, they came with the axle.
What should you buy? A dana60! Wait, they come with warn standards, it's a vicious cycle!
White K20
jeffahart is offline   Reply With Quote
Old 08-25-2017, 09:11 AM   #7
sweetk30
sweetk30's Avatar
Originally Posted by jeffahart View Post
The best: Yukon
1977-80/early 81 had spicer hubs
Old 08-25-2017, 12:06 PM   #8
jeffahart
jeffahart's Avatar
SRW, DRW of Both for the spice hubs?
White K20
Old 08-25-2017, 04:49 PM   #9
RANDY COX
RANDY COX's Avatar
Ok I went with Warn...
http://www.ebay.com/itm/WARN-Model-M...53.m1438.l2649
1964 BBC 402 4x4
Old 08-25-2017, 05:18 PM   #10
abig84
abig84's Avatar
ive ran a few different kind of lock outs on all my square bodies and never had any issues with any of them, warn, superwinch, mile marker and factory. even my current factory ones on my offroad truck hold up great. almost seems like its all amount maintenance especially if its on a offroad truck, take them apart every few months and clean all the water and mud out of them
abig84 is offline   Reply With Quote
Old 08-26-2017, 08:51 AM   #11
I agree with the above. Most break when user is trying to engage/disengage gritted up hubs. Also, many put grease in them, which is not what is called for and gets hard if not serviced often. These are outside of the wheel bearings and the only moving part is the actuator/knob. Just needs oil and regular cleaning.
I have a friend with a rolling '77 K30 4spd chassis I hope to scratch the dough up for.
Old 08-28-2017, 01:21 PM   #12
RANDY COX
RANDY COX's Avatar
Ok gottem installed....
https://www.facebook.com/photo.php?f...8972350&type=3
1964 BBC 402 4x4
