#26 |
![]() Join Date: Oct 2013
Re: WTF steering: 72 4x4 K5
Wheel bearings?
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
#27 |
Replaced the left bearings and repacked the right recently with no effect.
Thanks for the offer of help, Stokester. Maybe after this bext gearbox swap. We should meet up at No Label after the first cool front!
'72 K5, known as 'the Fox.' |
#28 |
Sounds good!! Just finished mine up! Only took 2 years!!! LMK if you need a hand. I have plenty of extra parts and a 84 parts blazer that still has some parts.
Posted via Mobile Device |
#29 |
#30 |
2nd replacement steering gearbox is in and... It's fixed! Really need the steering dampers back on now.
Some thoughts: I'm pretty sure the stop-leak power steering fluid was to blame. Shouldn't have been, but I really feel that's the case. That being said... The first replacement gearbox had a smaller input shaft than the original. The second is the same as the original. Same part numbers (according to O'reilly) but definitely different. Same steering problems between the original and 1st replacement, tho. It would seem that others that had the same symptoms as I did would be experiencing something with internal seals and such in their gearboxes. I pretty much ruined the 1st replacement box with that same stop-leak fluid, giving me the same problems I originally had. Others likely have the same problem but for different reasons (age, contamination, etc). Looks like those internal seals are clogging up the works in any case. The solution? A good replacement gearbox. Everything else may contribute to these symptoms, but in my case, the gearbox was the culprit.
#31 |
Glad to hear!!! Just in time! You might have to use her to get thru the flood!!! Stay dry and be safe!!!!
#32 |
Yeah kind of had to work into the night last night to get her done. Bring on Harvey!
'72 K5, known as 'the Fox.' Last edited by mister.freeze; 08-25-2017 at 11:51 PM. |
#33 |
![]() Join Date: Mar 2004
stokester, what size tires / lift are on your rig?
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
#34 |
