Old 08-31-2017, 09:30 AM   #1
Harleymike
rolling cab on its back side
Ive got my truck completely apart now. Cab is on rollers in garage.
I plan on laying it on its back (back window side). So I can work on the bottom of it.
Do you guys see any issue with this. I think it should be structurally fine. But thought i should ask the experts on here.
Mike
Harleymike is offline   Reply With Quote
Old 08-31-2017, 09:37 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: rolling cab on its side
I did that to weld up the dozens of holes previous owners had drilled through the floor for various things, including different seats. I also took the opportunity to seal, paint, and then finish the underside with some heat resistant acoustic coating.
I did set it on wood planks with a couple of 4x4s notched for the drip rail. I had a couple of friends help me with tilting, lifting, and setting the cab down.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-31-2017, 09:44 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: rolling cab on its back side
Piece of cake, I used 4'X8' plywood on the garage floor.
Old 08-31-2017, 03:01 PM   #4
racecougar
racecougar's Avatar
I placed a piece of heavy carpet onto a pallet and set the cab onto it with the help of a few friends. It worked out very well. If you're painting the interior, it's a good time to strip the roof as well. Sanding above your head isn't much fun.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 08-31-2017, 03:42 PM   #5
Harleymike
Awesome. Thanks for the help and suggestions. I guess its a done deal then. I'l flip it over.
