Old 08-31-2017, 09:21 PM   #1
atm70chevy
atm70chevy's Avatar
Temp sensor for AFR heads
Can someone please tell me what size temp sensor goes in AFR heads? I bought an AC Delco sender with 3/8 threads and it was too big...
Thanks for the help.
atm70chevy is offline   Reply With Quote
Old 08-31-2017, 10:28 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Temp sensor for AFR heads
Does the end of the sensor bulb fit into the hole in the head?
Do a search on this board for "coolant sensor modification".....one of the members here does the modification...he turns down the standard one and then recuts the correct thread size....
BTW...AFR will drill and size the coolant hole in the head if you tell them when you order the heads...
This entire scenario has been around for a while now...am left wondering why aftermarket folk are still asleep at the wheel...
AussieinNC is offline   Reply With Quote
Old 09-01-2017, 10:43 AM   #3
atm70chevy
atm70chevy's Avatar
Yes the end of the sensor will fit in the hole. The threaded part is too big for the hole in the head. I called AFR twice and was told both times the sensor opening was 3/8....
Old 09-01-2017, 11:05 AM   #4
Coley
Coley's Avatar
It looks like you need to investigate and determine exactly what you have.
They say the hole is a 3/8" threaded...and your part with a 3/8" threaded end doesn't fit. Can you find another 3/8" (Npt-pipe) part and try it to make sure that it isn't the AC delco part you have?
That said, you need to first determine that the hole is threaded...it might have missed the 'tapping' operation when it was getting made so it may be just the pilot hole. Use a small mirror or your fingers to determine that there is indeed a tapped/thread form in there.
If it is tapped you need to try a few different threads in there to determine exactly what they tapped in there....if they tapped it.
Can you feel a thread form in the head?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-01-2017, 12:32 PM   #5
AussieinNC
Moderator
AussieinNC's Avatar
3/8 Gas or NPT drill size is 9/16", I suspect the AFR tech cut the hole to 3/8 UNC...
Looks like you have a couple of choices,,,
have a shop drill and tap the hole to suit your sender or
source an adapter to convert from the small thread to the 3/8 gas thread of the sensor or
turn down the sensor body and re-thread the sensor to suit
Old 09-01-2017, 01:01 PM   #6
A1971Blazer
A1971Blazer's Avatar
There's a big difference in 3/8" SAE thread and 3/8" NPT....you need to be sure that it's 3/8 NPT...I can modify a sender for you..I may have one on hand that is already done..
http://67-72chevytrucks.com/vboard/s...r+modification
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-01-2017, 01:35 PM   #7
AussieinNC
Moderator
AussieinNC's Avatar
There you are ! If you read my first response, I mentioned a member who did the modification...
I am not sure what the actual size of the threaded hole is,,,ATM70Chevy should be able to advise...
Thanks for jumping in...
Old 09-01-2017, 02:00 PM   #8
AussieinNC
Moderator
AussieinNC's Avatar
There is another possible solution...put the sender unit in the manifold water port branch at the front of the engine.
Debate is open on whether the manifold location runs cooler than the head providing a possible inaccurate reading.
Manifold locations are usually close to or tapped to 3/8 NPT.
Old 09-01-2017, 11:15 PM   #9
atm70chevy
atm70chevy's Avatar
Thanks for everyone's responses. The problem was I'm an idiot.... The hole in the head is 3/8 and the temp sensor that I had and thought was 3/8 was actually 1/2.... I was having one of "those" moments! Haha
