Old 09-02-2017, 08:14 PM   #1
5 Driver
LS3 - Manual to Auto?
I may have an opportunity to get a 2010 LS3 tied to its 6 speed manual transmission. It comes with everything from the donor car to do the swap.
Question is, what, if any, issues will I run into if I want to switch it to an automatic? Say a 4l80e.
Thanks,
5 Driver is offline   Reply With Quote
Old 09-02-2017, 09:17 PM   #2
mongocanfly
mongocanfly's Avatar
Re: LS3 - Manual to Auto?
it can be done...but unless your getting a steal of a deal why not just buy a ls3 with a auto already behind it?..but..your gonna need everything from flex plate back plus a controller for trans and Im not sure what all else...
other than that a engine is a engine..you can put whatever behind it..I went from auto to nv4500 on my ls swap
Old 09-02-2017, 10:55 PM   #3
Captainfab
60-66 Nut
I have not done a swap such as this but my guess would be that you will need a complete wire harness and PCM for a LS3 with a 4L80E. You would likely get more answers if this was posted in the 'LSx Swaps' section.
Old 09-03-2017, 06:47 AM   #4
5 Driver
Thanks Guys,
Little green in regards to the electronics and such. Might better say a LOT green!
And yes....may have a pretty good deal on it. But it's not a good deal if I have to spend a lot on other components to get it done.
Old 09-03-2017, 06:49 AM   #5
5 Driver
It was recommended that I post this here:
Thanks,
Old 09-03-2017, 09:39 AM   #6
truckdude239
truckdude239's Avatar
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
Threads merged
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-03-2017, 01:22 PM   #7
5 Driver
My apologies David.
Old 09-04-2017, 11:41 AM   #8
Hart_Rod
Hart_Rod's Avatar
It can be done, but I wouldn't recommend it for a novice (no disrespect intended). Buy it and resell it and use any money you make to purchase one with and auto transmission.
Hart_Rod is offline   Reply With Quote
Old 09-04-2017, 11:53 AM   #9
5 Driver
Thanks Rob. Think I will hold off and do as you suggest. And, none taken..."iron sharpens iron..." Agreed!
