Old 09-02-2017, 11:56 PM   #1
718jwh
Heater core with A/C question
I am assembling my heater box with A/C and am wondering if there is any foam strips that go on the heater core or the box in the area where the core touches the box I don't remember if there was anything when I disassembled the old one. I am using a new aluminum heater core and was thinking there should be something between the aluminum core and metal piece it rest on in the box
John
718jwh is offline   Reply With Quote
Old 09-03-2017, 12:36 AM   #2
randy500
Re: Heater core with A/C question
I think there is strip caulk around the edge of the heater core.
randy500 is offline   Reply With Quote
Old 09-03-2017, 12:55 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I only know of a gasket between the heater box and firewall. That's how I found it, but the heater core was replaced once before.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-03-2017, 06:22 PM   #4
F.A.A.benny
I always use gum cord with these aluminum heater cores as they have more of a gap than the original Harrison heater cores had. If you look at the 5:25 mark on my video you can see some of the gum cord as I mentioned it while describing what was done to the heater box.https://youtu.be/F-07ekAClrM
F.A.A.benny is offline   Reply With Quote
