Closed Thread
Old 09-05-2017, 01:41 PM   #5776
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by toolboxchev View Post
Gauge was pointing about 2-4 mm over the first line in operating temperature,outside was very humid in the mid 90's. I had just taken it for a run on the freeway. Cooling systems can be a bear sometimes, I still get a little rust after a flush in my coolant reservoir. I should add also that I am using a 16 lb radiator cap which will flow both ways as it should with a reservoir.
The gauge never used to read this way that is why it got me worried. Gen I block with a hot Accel Super Coil HEI and R45ts plugs to burn off any oil blow by.
Do you think maybe the gauge is not working properly?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 09-05-2017, 02:26 PM   #5777
paul blair
Lookin GOOD Ned! I hope you will post some pics so we can see how much fun you are having. PB
paul blair is offline
Old 09-05-2017, 04:50 PM   #5778
RodnRudy
RodnRudy's Avatar
I installed my new LED tail/brake lights They are a ton brighter than the old 1157's. United Pacific brand, excellent quality.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 09-05-2017, 07:05 PM   #5779
AussieinNC
Moderator
AussieinNC's Avatar
Originally Posted by OregonNed View Post
Getting ready for the Rod Run in Long Beach, WA this coming weekend. With the potential for rain at the coast, I gave the wood bed a coat of crystalline wax ahead of time.
Seriously...that truck is way to nice to get its feet wet! Cool ride Sir...
AussieinNC is offline
Old 09-06-2017, 10:01 AM   #5780
toolboxchev
Yes I do, or that silly Harbor Freight infrared laser thermometer is way out of spec. I should have tested that thing against some boiling water. Someone on here has pointed out that the Teflon tape can interfere with an electrical connection.
toolboxchev is offline
Old 09-06-2017, 04:03 PM   #5781
NoStopN
NoStopN's Avatar
Drove it to breakfast. Then I took my cousin of a Chevy to the levee.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 09-06-2017, 04:57 PM   #5782
toolboxchev
Decided to continue on with dialing my motor in. Nuthin special but I like em to run like a top. Pulled the valve covers and marked all the pushrods with a paint pen to make they were all spinning properly.
HA! All working as hoped for, 70k on the top end all those Comp Cams lifters are working. Did a quick valve adjustment and only found on that was a tad loose. Got here buttoned back up and checked the gauges.
Revs to 5500 no problem, no ticks, knocks or worries at this point, GOING FOR A DRIVE!
Old 09-06-2017, 09:15 PM   #5783
beaterku
beaterku's Avatar
Removed the side windows, wing windows, window regulators and door latches in both doors. Replaced a broken door latch relay, new wing windows and precision door wipes. While I was in there, cleaned up both regulators, painted and greased. Ditto for the door latches. Also installed a new lock set and adjusted the latches. Doors closes soft and lock for the first time in years. Also installed a little dynamat in the doors to soften the thud a little.
beaterku is offline
Old 09-06-2017, 10:20 PM   #5784
b.sharp
b.sharp's Avatar
Hauled my tractor to the in laws to do a little bush hogging this weekend. My truck likes to work and does it well.
b.sharp is offline
Old 09-06-2017, 10:23 PM   #5785
Steeveedee
Who Changed This?
Steeveedee's Avatar
Drove it! My youngest son is driving my econobox to work while his car that he bought three months ago gets repaired, so I'm driving it. Some debris came out from under a truck while he was on his way to work, and he ran into it, with no place to dodge. 2017 KIA Soul with only 2600 miles on it. The radiator core support was lunched, because it is plastic. My truck would have laughed at that debris, and said, "That all you got?", and flipped it into the next vehicle back...munch.
~Steven
Simi Valley, CA
Steeveedee is offline
Old 09-11-2017, 11:51 AM   #5786
Ekliptix
Ekliptix's Avatar
Added these 2 stickers.
White sharpie'd the tire lettering for them to 'pop'. Actually, the lady did it.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline
Old 09-11-2017, 12:09 PM   #5787
mud.man.rj
mud.man.rj's Avatar
Ah come on, the lady did your letters, smart move she looks very patient.
The factory stickers add the little missing pieces. Nice touch's.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 09-11-2017, 11:36 PM   #5788
rustytruck50
rustytruck50's Avatar
At the request of my Wife, I replaced the crusty broken down armrest pad on the drivers door....picked it up @ Classic Parts of America in KC this last weekend...maybe if she takes more opportunities to drive the truck, there will be more requests for upgrades
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline
Old 09-12-2017, 12:41 AM   #5789
OregonNed
OregonNed's Avatar
Got back from a car show on the coast last weekend. It rained a lot of the time so had to do the usual cleanup. It was a great time A good number of C10s during the cruise.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 09-12-2017, 07:48 AM   #5790
paul blair
Hi Ned, Any pics to share from your cruise and show trip?
Old 09-16-2017, 01:39 AM   #5791
wpavlis
Fumbled my way through a chassis greasing session
wpavlis is offline
Old 09-16-2017, 09:38 AM   #5792
Johnnyrotten_72longb
I Picked it up!!! MINE ALL MINE!!!
Johnnyrotten_72longb is offline
Old 09-16-2017, 10:31 AM   #5793
72_swb
72_swb's Avatar
Congratulations johnny. Enjoy. Looks good
72_swb is offline
Old 09-16-2017, 11:18 AM   #5794
Going to be a project, but its a driver currently. cant eat an elephant all at one meal, gotta take it bite by bite. Eventually it will rival your beauty!! But thanks
Old 09-16-2017, 01:28 PM   #5795
Gillnetter
Gillnetter's Avatar
Got my bed wood in!
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline
Old 09-16-2017, 06:01 PM   #5796
Possmguts
Possmguts's Avatar
Originally Posted by Gillnetter View Post
Got my bed wood in!
Looks really nice... what a pain in the butt right?
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 09-16-2017, 09:15 PM   #5797
FRCvette
Installed 2 1/2 inch drop spindles and 1 inch lower springs.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline
Old 09-16-2017, 11:50 PM   #5798
rustytruck50
Installed my eBay Camaro/Vega GT steering wheel, upgraded my '80s era 6x9 door speakers with a $20 pair of Swap Meet Pioneer's (best money spent in quite awhile) & installed the middle seat belt I bought from Speedway last year....inching up on it! Lol
-Doug
'05 RCSB Sierra 2WD
Old 09-17-2017, 01:58 AM   #5799
In The Ten Ring
Made good gains (yesterday as it's now 2 AM). Removed grill and passenger side outer fender. Chased threads (dad did this) on four bolt holes we had cross threaded into getting that far in assembly.
I opened up 1 hole in the core support and 3 holes in the grill brackets with a die grinder after making those with chalk. Put fender and grill back on. Now only 1 hole won't line up (naturally one that did line up last time---SMH).
So I am closer to having it together!
In The Ten Ring is offline
Old 09-17-2017, 10:53 AM   #5800
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
I loaded the ramp truck up Friday and had new forks built for the chopper!
Yea it's a bicycle!
Red Neck Enigneering motor cycles cut me some 1-1/4" tubes for it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Closed Thread
