drip drip drip goes the tranny
I know one of you out there will have a simple fix for this problem. My 78 Chev (350/350TH) leaks tranny fluid where the speedo cable goes into the trans. I replaced the O-ring but it didn't make much difference. Is there a particular procedure I should be following or better brand of 0-ring ????
Thanks!! ![]()
Currently in and around my garage: 1978 Chevy Stepside (Elvis) 1993 Chev S10 ext cab (LittleTruck) 1998 Chev Astro Van (Wife's Hauler) 2001 Honda 1500 Valkyrie Interstate (dad's toy) 2003 Honda 1800 Gold Wing (mom's toy) |
You get what you pay for
![]() Join Date: Dec 1999
I'm guessing you replaced the o ring on the sleeve. There is a seal on the speedo gear shaft too.
Mike 1985 Chevy C-10 |
Insert Witty Text Here
I was able to buy a whole new "bullet" with inner seal and outer o-ring for just a few dollars at a transmission supply place. That ought to fix your problem unless there is a rough spot on the gear or something that eats up seals.
Slonaker |
Thanks for the ideas. I'll check with the trans shop..........
Cool thread.
I've got the same problem-- minor, but annoying.
Semper Paratus |
Right turn Clyde
I just went to the HELP section and bought an assorted O-ring pack. Put one in that fit the best and all fixed. Mine didn't have one at all in there somehow.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
BeWarE tHe eViL CrAnkTOe!
Guys..its not an o-ring....its a gasket that looks more like a top hat that has its top cut out. Its harder plastic than an o ring also. Like 2 bux and a pita to put in....
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
Right turn Clyde
got any pictures of it?
Here's the seal I'm talking about. This is what my 700R4 uses. I'm guessing a 350 uses something similar.
Oh my bad guys...on the speedo mike is correct... I was thinkin about the kickdown cable.
These are for my TH350C. They are resting on the receipt, so you can see how cheap they were ($5.90 for the pair). I'll install them one of these days.
![]() Speedo cable bullet with seal and o-ring preinstalled (side view) and new speedo gear: ![]() Speedo bullet (end view of seal): ![]() Damn! This cheap little camera takes good close-ups! The bullet in the pic above is only about 3/4 inch in diameter... ![]() Slonaker Last edited by Slonaker; 04-16-2004 at 12:47 AM. |
