can disc brakes be installed on a 62 c-40?
I can't do the front drums with one master.
At the body shop.
Re: can disc brakes be installed on a 62 c-40?
Pics of the front suspension? If it's independent I believe later model til 87 1 ton would be an easy swap.
" That didnt make it any newer " " Dont antique the equipment " |
#3 | |
I've always heard of the 79-85 front suspension swap, I may do that from a 1 ton. |
At the body shop.
I've heard the same. And I know they are really easy to get out, tie rods shocks brake hoses and about 6 bolts.
The whole x member and A arms come out as 1 unit.
At the body shop.
While your there get the hydro boost master cylinder and proportional valve too.
#7 | |
I'm either going to buy a complete donor truck or buy parts from a truck. I'll install disc brakes, hydro boost and a TH400 trans out of a newer chevy truck. Once thats installed, I can then run a hydraulic winch through my hydro boost system. Most of these truck came with a 454 but I don't know if I want to go that big, but hey, if it comes with a truck then ya never know...... |
At the body shop.
Very cool truck too.
I like this thread.!
. ........................S . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
Well, I'm installing hydroboost disc brakes, 454 engine and a TH400 trans. I started tearing into a truck today to get my parts.
I'm going to make a safe FAST and trustworthy 60's ramp truck! |
At the body shop.
Get the rear end out of the donor. Should be 4.10 or 3.73:1 should taller than what's in the current rear end be able to get parts
The later K members should swap over. On my 63 1 ton panel I used a donor 84 truck. The 3 main bolts that bolt in vertically should mount right up. 2 on the side should also bolt up. You will have to drill one new hole and oblong another and that's about it. That's assuming this has a similar width frame.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721 Instagram: jaked937 |
#13 | |
I tore into my donor truck and now have a front and rear suspension along with a 454 and TH400.
I bought the truck delivered to my door for $1000, sold the aluminum box for $200 and the rest of the truck for $80.00, not bad. |
#15 |
I found a badass lettering painter and he drew this up in like 2 minutes.
#16 |
At the body shop.
Love this truck. Knee knockers and all
#17 |
Thanks! I did the K member swap on my panel. Wasn't hateful. Think I'm going to try to swap a K member from a 92 G30 onto my 66 C50!
