Old 09-12-2017, 08:22 AM   #726
Bennett68C10
Bennett68C10's Avatar
Re: Bowtie468's Extreme '68 BuildPage
Good choice Chris, I like the 20's in the front better.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 09-12-2017, 09:24 AM   #727
smbrouss70
smbrouss70's Avatar
Your truck is nice and all, but check out that Brown truck up by the shop!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-12-2017, 02:44 PM   #728
Camaroguy
Camaroguy's Avatar
This truck is amazing! I just looked through the entire build and the only negative I thought about was that you should have done 20's up front. Looks perfect now. Seriously, beautiful truck!
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD)
Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712
Camaroguy is offline   Reply With Quote
Old 09-12-2017, 11:27 PM   #729
Bowtie468
Bowtie468's Avatar
20's all around look so much better in my opinion.
Beautiful truck.
Thanks Keith !
Originally Posted by gringoloco View Post
Yup, dig it
Glad to hear that Chris !
Originally Posted by rustytruck50 View Post
Beautiful truck!
Thanks, I appreciate that !
I agree. Thanks Keith
LOL!!
Thank you !
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 09-21-2017, 02:48 AM   #730
Bowtie468
Bowtie468's Avatar
Another upgrade to add to the list. Gonna be a busy winter at the shop !
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 09-21-2017, 05:16 AM   #731
darkhorse970
darkhorse970's Avatar
Sweet! You are building the ultimate truck brother!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 11-01-2018, 01:38 PM   #732
ckid1971
ckid1971's Avatar
Originally Posted by Bowtie468 View Post
Another modification that i wanted was the addition of a 3rd brake light to the back of the cab. After looking at various units, i finally settled on the 16" Hot Slot from Watson's Streetworks. Because of the size of the light, the inner panel had to be cut out to get it mounted in place. It's pretty unnoticeable when it's off, but when you hit the brakes, it's impossible not to notice it ! In the last picture, you can see the acrylic lens protruding past the surface of the sheet metal. This lens was blocked down to match the contour of the cab panel, but not so much as to make it flush with the panel. It actually needs to wind up flush with the basecoat, which wasnt on yet. And let me stress that they dont sand too easily ! This was a bit tricky as you dont want to pile on basecoat to make it flush. A little more work than i thought, but the end result was well worth it !!
What grit did you block it down with?
ckid1971 is offline   Reply With Quote
Old 11-01-2018, 07:58 PM   #733
ajgriffin
ajgriffin's Avatar
NICE! Looking forward to you detailing the install and your feedback on how it goes!
Have you been able to put many miles on it since you "finished" it?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 11-04-2018, 09:44 PM   #734
Bowtie468
Bowtie468's Avatar
a courser grit such as 60-80 is needed to cut the acrylic lenses down to the metal. After that, just block with the body as you normally would.
Have you been able to put many miles on it since you "finished" it? [/QUOTE]
Nothing to write home about. Its got around 1300 troublefree miles on the odometer. Still a fresh build if I decide to flip it
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 11-07-2018, 09:20 PM   #735
Bowtie468
Bowtie468's Avatar
Havent been here in a while. Ill have to look back on the thread as im sure ive got pics that never got posted.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 11-07-2018, 09:31 PM   #736
ckid1971
ckid1971's Avatar
Nothing to write home about. Its got around 1300 troublefree miles on the odometer. Still a fresh build if I decide to flip it [/QUOTE]
Old 11-07-2018, 09:38 PM   #737
Bowtie468
Bowtie468's Avatar
found one
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 11-07-2018, 09:39 PM   #738
ckid1971
ckid1971's Avatar
Thanks for the info.
Appreciate it!
Old 11-07-2018, 10:11 PM   #739
Bowtie468
Bowtie468's Avatar
found one
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 11-08-2018, 09:55 AM   #740
gringoloco
A guy with a truck
gringoloco's Avatar
Beauty! Makes me want to 68 clip my junk, if I ever decide to paint it
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-08-2018, 03:27 PM   #741
68Gold/white
Job well done!!!
68Gold/white is offline   Reply With Quote
