Re: Need advice on fixing broken rocker stud on Big Block..
Did a little more digging around and think it's time to consider plan b.
I pulled a good stud out so I could get some measurements. Then I noticed this stud is mared where the rocker sits on the shroud. Wondering if I need longer studs and shanks for the rocker to sit on? ![]() Then I looked closer at the #1 cylinder spring and see two of the coils touching and look on the back side to see the spring is cracked. So now this is a whole new problem. Since now the heads need to come off, I guess my plan b choices are: 1) aftermarket heads (didn't really want to spend that kind of $$ right now) 2) have my local machine shop rebuild the heads (most likely it would just make financal sense to do #1) 3) do a quick patch job myself with new studs and springs. Never done this and I don't have all those tools. My guess is $400 - 500 in parts and probably 2-3 months turnaround for me. 4) LS swap, just because that's what everyone is doing now-a-days. Thanks again for everyone's help. I've learned a lot on a topic I have zero experience with. Brian
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
| Bookmarks |
