Old 02-23-2017, 03:58 PM   #76
CustomCab66
CustomCab66's Avatar
Re: 1966 C1434 SWB Custom Cab
Here are close ups of the two wheels.
CustomCab66 is offline   Reply With Quote
Old 02-26-2017, 08:35 AM   #77
northern 85
northern 85's Avatar
Very nice !!!
northern 85 is offline   Reply With Quote
Old 06-23-2017, 09:34 AM   #78
CustomCab66
Well stuff is falling out of the bed so out with the old wood so I'll be posting from time to time
Old 06-23-2017, 09:38 AM   #79
CustomCab66
Talking Re: 1966 C1434 SWB Custom Cab
For the true Chevy truck enthusiasts here is a picture of the original grease pencil marking on the brace at the end of the frame rails. It's is marked C1434
Old 06-24-2017, 09:37 AM   #80
jocko
jocko's Avatar
enjoying your build thread for the first time and will be checking back on progress. Really like the way you're doing things right as you go along. Had a very similar 66 swb bbw and do miss it! Looking forward to the progress.
Old 07-07-2017, 12:49 PM   #81
CustomCab66
Now that I'm back from the coast it's time to get back into the garage. Almost ready for some black paint. I'm hoping to get the bed back together this weekend. All the wood is cut to the proper width which is 6 3/8 at the corners, 7 7/16 starting at the wheel wells, and the two in the middle are 5 7/16.
Here's the link to GMC Paul's site for the wood info:
http://www.gmcpauls.com/47-72_BedWood_Info.htm
Old 07-08-2017, 06:59 PM   #82
CustomCab66
Burning the midnight oil last night trying to get the boards painted so they could dry over night
Old 07-08-2017, 07:01 PM   #83
CustomCab66
Spent the better part of half a day installing the wood today but it was worth it.
Old 07-15-2017, 08:23 AM   #84
northern 85
That looks great!!!
Old 09-03-2017, 07:53 AM   #85
CustomCab66
Well I hate to part ways with my old SBC 400 but when it's time it's time. This managed to follow me home so now I preparing to drop this combo in there.
Old 09-03-2017, 08:00 AM   #86
CustomCab66
3/8 Fuel line added to the sender to feed the fuel pump through a 100 micron filter. The word on the web is to use a Walbro pump which seems to be inexpensive
Old 09-03-2017, 08:14 AM   #87
CustomCab66
In order for the lock up torque converter to function properly a constant 12 volt source needs to be wired to pin 33 on the PCM. The switch in the image is a corvette brake light switch which has normally open and normally closed contacts. I did change it up instead of using the jumper I ran an ignition hot ( pink wire) to the normally closed side of the switch while the button was depressed (foot off the brake peddle state).
Old 09-03-2017, 08:38 PM   #88
CustomCab66
I ran the fuel line today so that it exits the floor by the original line
Old 09-04-2017, 02:43 PM   #89
bj383ss
bj383ss's Avatar
So I guess you are using the old line to run the return line to?
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 09-12-2017, 02:13 PM   #90
CustomCab66
Bret
Yup. So the LS came with a 3/8 pressure line and a 5/16 return line. I have a Walbro inline fuel pump but I still need to get the fuel filters and misc fittings. To be continued
Old 09-13-2017, 02:16 PM   #91
okndn
I really like what you are doing, mostly with the LS swap, and want to see the whole thing completed. The LS is my plan on my truck
okndn is offline   Reply With Quote
Old 09-13-2017, 02:51 PM   #92
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'll be watching from this point forward.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is online now   Reply With Quote
Old 09-22-2017, 09:36 PM   #93
CustomCab66
So out with the old. I'm interested in seeing what was causing #8 cyl to burn so much oil. It would foul a plug every 30 miles at highway speeds
Old 09-22-2017, 09:39 PM   #94
CustomCab66
Look at the build up on the exhaust valve. Is it 1/16 of an inch thick piston seems to be pretty clean considering how much oil it was burning.
Old 09-23-2017, 01:43 PM   #95
CustomCab66
So my garage floor is covered in SBC parts all of which are in excellent shape. The 882 cast heads are nothing special but because of the comp cams extreme energy cams .477/.480 lift I added comp springs, guide plates, and screw in ARP rocker studs. Next thing on my agenda is to pull the oil pan and pistons I want to see what #8 looks like
Old 09-25-2017, 09:27 PM   #96
CustomCab66
Number 8 piston was the one giving me trouble. But I found that the top ring gland on #3 had some damage from pre detonation or heat and the top ring was broken in three places. The engine has always had a weird noise on the rotating assembly. Maybe this was it
Old 09-26-2017, 06:58 AM   #97
bj383ss
bj383ss's Avatar
Did you pull the short block out already?
Bret
Old 09-28-2017, 11:31 PM   #98
CustomCab66
Bret
Not yet but getting close. Gonna drop the tranny first slide it out then work on removing the block. I do not have an engine hoist so it'll have to come out the bottom.
Old 10-05-2017, 12:16 PM   #99
CustomCab66
Attachment 1696118The whole front end is off hopefully will be able to stick the LS in place and finish the motor mounts.
Old 10-05-2017, 06:24 PM   #100
CustomCab66
So I set it in there and now it's a matter of figuring out the engine placement fore and aft so that I can drill the holes for the motor mounts. TO BE CONTINUED
