#126 |
Re: static dropped square bodies with 15s
Here's Mine on 15's 5" Front, 7" Rear
#127 |
What size tires?
#128 |
#129 |
#130 |
#131 |
4,5/6 drop with BellTech spindles, springs, flip kit and shocks.
15x10 American Eagle 589 rims with 295/50 and 255/60. Had to grind back the lip on the lower control arm for clearence. Rides like a gocart and is real fun!
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ![]() ´81 GMC C 10, Spanish Red |
#132 |
#133 |
Thank you! My pride and joy for 24 years now!
#134 |
85/Silver,
It is PPG 50775 Cordovan Maroon. Moneyeater, I love your truck, might have to copy your tire size!
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532 |
#135 |
I will be joining this thread soon. I plan to loose my current 17's for a set of 15" Ansen Sprints with BFG T/A.
#136 |
85super,
What don't you like about your 17" rims? I was thinking of going to 17s but not sure. If I don't, I thought about the same style rim you want to go to.
#137 |
Huston Ben, there is nothing wrong with my 17's. they where in the truck when I bought it. They are Helo Max 6 and look to 4x4ish for me. I am going with the 15's for the classic look. Not to mention a set of 4 rims and tires together cost less than one Schott rim that was my other option.
#138 |
#139 |
2.5/4 drop with western chassis drop spindles up front and drop leafs springs in the back
#140 | |
![]() Join Date: Jul 2000
I have Beltech dropped hangers and WC shackles on the shelf, but can't decide which set or combo to use for a 2"-3" drop. If I do the hangers I'll need to drop the tank. Using the shackles requires notching a bed support member, which I hate to do. ![]()
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#141 |
I ordered them from the Western Chassis website. Install was easy. I went with these so I didn't have to cut the support for the shackles or go through the trouble of grinding rivets and relocating the hangers. You could purchase the 3" drop leaf springs and remove a leaf to drop it to 4 inches if you don't like the stance. It didn't quite get me to 4" of drop but I'm pleased with the results. I'll put a link below
https://westernchassisinc.com/1973-8...-Leaf-Springs/ |
#142 |
5.5/7 drop on 15x7 front and 15x8 rear.
#143 |
A static Drop is not cutting the frame rails?
#144 |
![]() Join Date: Apr 2013
15x8 rallys all around
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
#145 |
You guys with 5/7 drops, is there room for a 15x10 Rally wheel with 275's mounted in the rear?
#146 |
A static drop is just simply a drop that is at a fixed height - it doesn't change. Examples would be drop springs, drop spindles, axle flips, or shackle relocators, once installed your ride height is set. Guys with bags on their truck can raise or lower the suspension height at will.
#147 | |
#148 |
I'm just glad to be here!
Yes. We even ran a 295/50-15 on a fleetside...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#149 |
Cruzzzn' Vet
My 83, 15x8, 15x10
