Old 09-15-2017, 09:47 AM   #1
Mike_Mc
LS conversion motor mounts?
Looking for some advice on LS swap motor mounts for my 68 step side? Took out the straight 6 and there are so many companies out there making them. Seeing if anyone had good experience with one company from another.
Mike_Mc is offline   Reply With Quote
Old 09-15-2017, 10:11 AM   #2
nightrider388
Re: LS conversion motor mounts?
I bought the newest CPP sheet metal engine and frame mounts from summit racing. They fit perfect. My truck is a 70 c10
nightrider388 is offline   Reply With Quote
Old 09-15-2017, 11:16 AM   #3
'70_402
'70_402's Avatar
I've got the CPP mounts also.. perfect fit.
'70_402 is offline   Reply With Quote
Old 09-15-2017, 12:13 PM   #4
dgheinen
Dirty Dingo Sliders look really promising. The nice part about them is that depending on your previous setup, you can just slide the mounts forward and back to hopefully maintain your previous driveshaft. With a lot of the conversion mounts out there, there are only a couple pre drilled mounting locations. With the sliders, you can fit it exactly where you want to.
dgheinen is offline   Reply With Quote
Old 09-15-2017, 12:36 PM   #5
Mike_Mc
CPP were the ones I was leaning towards but just wanted to see if anyone had experience with them. Thanks
Old 09-15-2017, 12:58 PM   #6
Steve Cole
Do the CPP mounts put the LS engine in the same position as the stock V8 ?
Steve Cole is offline   Reply With Quote
Old 09-15-2017, 02:05 PM   #7
nightrider388
CPP mounts are adjustable. The frame mounts do go in the stock location. CPP engine mounts are adjustable within reason very similar to the dirty dingo sliders. I chose the cpp mounts because I did not want to drill holes in my cross member. The sheet metal frame mounts bolt in stock location.
Old 09-15-2017, 02:07 PM   #8
nightrider388
This might get moved to the LS swap section.
Old 09-15-2017, 03:15 PM   #9
68Stepbed
68Stepbed's Avatar
I used these from POL. https://www.performanceonline.com/19...-Brackets-V-8/
They work in either the V8 or 6-cylinder position, clearance for any kind of headers or manifolds, look clean and simple. Don't use the cheap Chinese rubber mounts, though. Go ahead and get the Energy Suspension urethane mount upgrade.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-15-2017, 04:04 PM   #10
indymachinist
I recently dropped my engine in on Early Classic mounts. Its not done yet but I like the way it sits. Fits well with a ctsv pan that is easily available, has room for a low mount a/c compressor with minimal frame tweaking, and allowed a 4l80e to go under a low hump tunnel.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-15-2017, 08:00 PM   #11
racecougar
racecougar's Avatar
I used the Speed Engineering adapter plates...they worked well.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 09-16-2017, 01:24 AM   #12
SierraMtns
SierraMtns's Avatar
Matt,
Did you get the LS Conversion Brackets too? Looks like everything is $284?
SierraMtns is offline   Reply With Quote
Old 09-16-2017, 01:29 AM   #13
SierraMtns
SierraMtns's Avatar
Are these the ones?
https://www.speed-engineering.com/ls...3-ls6-ls9.html
I don't see any for our year trucks.
Old 09-16-2017, 07:35 AM   #14
racecougar
racecougar's Avatar
Originally Posted by SierraMtns View Post
Are these the ones?
Those are the ones. Those pair up to the stock type motor mounts and I-6/V8 perches.
Old 02-06-2019, 04:20 PM   #15
MDPotter
MDPotter's Avatar
It looks like these worked well for you? I have a 68 C15 and I want to reuse the stock perches (look just like yours-see top picture) but it seems like most of the LS motor mount plates are made for the other type of mount which has a thru-bolt (see bottom picture) rather than the bolt through the back of the motor mount like mine (top picture). I'm told that the 3-bolt pattern is different between the two style mounts too. Do you have the style like mine (top picture)?
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 02-06-2019, 04:36 PM   #16
nightrider388
Attachment 1873006
Attachment 1873007
The 3 bolt part is the part that actually mounts to the LS engine. That bolt pattern will remain the same no matter which mounting style you use. The single through bolt simply attaches to a certain type of frame mount or plate that goes to the cross member. Its just the attachment point style that has to match which frame mounts you have.
Old 02-06-2019, 05:08 PM   #17
MDPotter
MDPotter's Avatar
There are (4) bolts that attach the plate to the LS block. What I want to confirm is that the Speed Engineering plates will work the style of SBC mounts I have (single bolt through the face of the stock perches). What racecougar appears to have in his pictures is the same perch and mount I have, but I want to confirm that it worked out for him before I order the Speed Engineering plates.
Are you saying that both types of SBC mounts have the same 3-bolt pattern and will work with any of the LS plates?
Old 02-06-2019, 05:21 PM   #18
nightrider388
Well the style I used has a plate that bolts to the (4 bolt) engine side. Then it has the 3 bolt similar to what you have in photo. I'm not saying that they all will fit the same. I know you have to buy the right kind that fits the style of frame mounts you have. I wouldn't personally want the fixed kind. Depending on which style pulleys you have and oil pan, the adjustable ones let you slide them to the front or back as needed to clear firewall and crossmember and pulleys. Sorry to make it sound confusing.
Old 02-06-2019, 05:27 PM   #19
MDPotter
MDPotter's Avatar
Hopefully racecougar responds, but I will probably end up buying the Speed Engineering plates. They aren't sliders like most plates, but they have multiple holes for a total 2-1/4" of adjustment via (4) sets of holes. I'm not running A/C so that will eliminate some of the clearance concerns typical of these trucks.
Old 02-06-2019, 05:33 PM   #20
nightrider388
But just guessing. I would say they will all fit the frame side the same. I think basically all the conversion mounts do is flip the ls style to fit a factory configuration. Worst case if it didn't line up, you drill the plates and put the mount where you want it.
Old 02-06-2019, 05:51 PM   #21
jrusher
I used the dirty dingo sliders on my 65 they worked awesome was so nice just to quickly slide the engine back and forth to position it . On my wife’s 61 I’m trying the ICT ones off Amazon they have multi holes for different positions
jrusher is offline   Reply With Quote
Old 02-06-2019, 09:06 PM   #22
racecougar
racecougar's Avatar
MDPotter, the Speed Engineering adapter plates will work for your mounts without issue.
Old 02-07-2019, 12:09 PM   #23
AZ 67 C10
AZ 67 C10's Avatar
If you want to use the factory perches and have the bolt through the back of the motor mount use these. https://www.summitracing.com/parts/ens-3-1156g
I used factory perches with those motor mounts on dirty dingo sliders. It can be a pain by yourself to get the bolt lined up going from the perch to the motor mount since you can't really see it.
Do some aftermarket perches that have the bolt through style change the motor height/position compared to the factory perches? I see some people run the AC compressor down low and some move it up because of clearance.
AZ 67 C10 is offline   Reply With Quote
Old 02-07-2019, 03:26 PM   #24
Nick_c10
I used the dirty dingo sliders on my 68 and I didn’t like them for a couple reasons. They sit up 1/4 higher than stock so I had to bend the tab back in the transmission tunnel with my 4l60, and also if you want to slide the motor all the way forward you have to trim the passenger side rubber mount. But other than that they worked and looked nice.
Nick_c10 is offline   Reply With Quote
