Old 09-16-2017, 03:25 AM   #11
buffydores
buffydores's Avatar
Re: 1978 Russet Metallic 4x4
Yeah, that's not right. Mounted like that, you can shear the ratio adapter off and dump ATF on the ground, damaging your case in the process so the unit's no longer rebuildable. I'd make them fix that. Sorry to chime in with a negative, but that needs addressing. Looking forward to seeing your truck on the trail event and want to see you finish it too!
I'm not as concerned. There is quite a bit of clearance there. I'll holler at the rebuilder to get his input on the matter.
