Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-04-2017, 11:02 AM   #1
johnny burban
1966 suburban towing capacity?
im a owner of a c 10 1966 custom suburban. ive been looking at airstream to buy 20 -25 foot and has a gross weight of 5500 lbs. what is the capacity of my truck for pulling a trailer that size and weight? thanks for looking. any ideas?
johnny
johnny burban is offline   Reply With Quote
Old 04-05-2017, 11:48 PM   #2
Captainfab
60-66 Nut
Re: 1966 suburban towing capacity?
The GVW info is on the tag that is riveted to the drivers side kick panel. The towing capacity is going to depend on a few factors. Such as what engine is in your Suburban and what it has for brakes.
Old 04-06-2017, 12:01 AM   #3
johnny burban
thanks. it has a 350 400 thm drum brake not power and e brake install. tag says 5500 which i thought was the weight of the truck?
johnny
Old 04-12-2017, 11:06 AM   #4
1966burb
1966burb's Avatar
You will want disc brakes on front and good HD trailer hitch. I would use weight distributing hitch and sway control. Coil springs in the rear are also an added problem. I put new progressive weight coil springs in mine along with air shocks. I have towed lots of trailers with other rigs but my burb has been a challenge with only a 16 foot vintage Shasta trailer.
1966burb is offline   Reply With Quote
Old 04-12-2017, 11:54 AM   #5
bpmcgee
bpmcgee's Avatar
Yeah, the thing I'd be most worried about is stopping with drum brakes. Just don't have the same authority that disks do.
B
bpmcgee is offline   Reply With Quote
Old 04-12-2017, 03:33 PM   #6
johnny burban
OK thanks guys. i thought i may have been dreaming to big. I just got the truck so i may start with the disk brakes first. We still have so much snow outside the shop so it will be a while until i bring the truck out. thanks for the great ideas and the helpful info
johnny
Old 09-16-2017, 05:36 PM   #7
mMad Dawg
you might also consider going with a hydroboost system instead of a vacuum booster.Your brakes will work way better.
mMad Dawg is offline   Reply With Quote
