Closed Thread
Old 09-17-2017, 12:37 PM   #5801
RodnRudy
RodnRudy's Avatar
Re: What did you do to your truck today? Chapter II
I picked up a high note horn at the swap meet Friday. It's from a 66 Nova but I don't think my 68 C10 will notice the difference. With a little ingenuity I was able to combine the two horns and install them in the stock location. It's a lot better sound than just one low note horn.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 09-17-2017, 05:42 PM   #5802
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Two years in and I've actually finished something. Just rattle can primer & paint, but good enough for these:
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 09-17-2017, 10:43 PM   #5803
Possmguts
Possmguts's Avatar
Started the roll pan and flush mount tail lights today...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 09-17-2017, 11:24 PM   #5804
mud.man.rj
mud.man.rj's Avatar
Nice tailight idea and work.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 09-18-2017, 09:14 AM   #5805
72tutone
Installed front windshield, carpet, benchseat and belts over the weekend.
I will provide my utmost sympathies to whoever wants to tackle the windshield.
What a PITA!
Strange, the pics are not rotated before I uploaded them. Sorry about that
72tutone is offline
Old 09-18-2017, 09:47 AM   #5806
flashed
Looks very nice .
flashed is offline
Old 09-18-2017, 12:52 PM   #5807
Ekliptix
Ekliptix's Avatar
Love that green interior. I have a dark olive green truck and what you did would look terrific in mine. Or saddle brown.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline
Old 09-18-2017, 01:01 PM   #5808
72tutone
Thanks guys. Its been a loooong time coming. I started dismantling the truck 7+ yrs ago. I'm just now reassembling when life and cash dont get in the way. Time flies!!!
72tutone is offline
Old 09-18-2017, 02:14 PM   #5809
FRCvette
Drove it this morning to do my walking. Came back home and changed the oil. Took it for another drive. Came back home and adjusted power steering pump bracket to stop belt squeal. Went for another drive ( love driving this truck). Start tomorrow cleaning it up to get ready to go to James Dean run this weekend.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline
Old 09-18-2017, 06:52 PM   #5810
aventur1
aventur1's Avatar
Went to car wash, took a short drive. Wanted to keep going but went home...
That's about it, everything worked as usual.
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline
Old 09-19-2017, 02:21 AM   #5811
71CHEVYSHORTBED402
While my axle plates are in a rust bath, I figured I'm close enough to take-off to start inventory of what's being sent out out for plating. Every aspect of everything, checking my notes, etc. It's tedious, and I see I haven't cleaned everything up as I go, so two pots of hardware. I've learned to dislike cleaning hardware, but I do like the results.
I had some impression much of the hardware was the same on these trucks, but nope. I'm 1/5th done, and so far, near nothing has been the same across components.
Tony
Old 09-19-2017, 07:33 PM   #5812
RodnRudy
RodnRudy's Avatar
I finally got around to replacing my old HEI distributor with the new GM HEI unit I got from Summit last month. It only took two tries to drop it in the correct position on #1 cyl. a first for me.
Phil
RodnRudy is offline
Old 09-20-2017, 03:43 AM   #5813
In The Ten Ring
Thanks for the pic! I put my horn back on yesterday having to guess how it went back.....looks like i put it on correctly.
(I have a 3 horn set off a Cadillac, I plan to put those on my truck in the future).
Yesterday I put on the battery tray, horn, cleaned up some lighting connectors, put the external regulator back on, cleaned up the wiring a bit (wiped it off), and began installing the new front wiring gutter. *It is very exciting to be this far along.
In The Ten Ring is offline
Old 09-20-2017, 09:43 PM   #5814
2 Far Gone
Installed new rear brakes, hardware, wheel cylinders, drums, stainless lines and stainless flex line....even cleaned and painted the rear axle!
On to the front axle now
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=611571
2 Far Gone is offline
Old 09-23-2017, 11:23 PM   #5815
71CHEVYSHORTBED402
Inventory of parts I'll send out for black zinc. Phosphate a possibility. Wholly cow there are a lot of parts, especially with A/C. I'm also retracing my notes to make sure everything is right & tight. It's not fun, and I'm beat. I've discovered I only cleaned maybe 70% of the parts along the way. The balance shouldn't be bad, but another 100 plus parts to clean. I have a real distaste for the small wire launching wheels on a Dremmel, but they work well.
I'm about 90% done. So far I've accounted for the hardware for 120ish components, total 392 pieces. Sadly, I can tell you ever aspect for everything. It snowballed as I was learning, and what the heck, just as well note the stamps.
Edit, BS I was 90% done. Shot up to 541 pieces, and I found 50-60 nice spares I have to add yet. That doesn't include washers and most nuts. I'll add shocks hardware for good measure. Have to pull the suspension, engine/trans yet, but they won't produce much. Still, I never imagined I'd have well over 600 plus pieces for plating or coating. Adds up pretty fast.
If I have them zinc plated black, I may send the same place the steel retainers & clamps (e.g., tube retainers) for "clear" or yellow plating. Wouldn't hurt to add some more yellow in there. Any grade 8 that needs replacing is going to be yellow zinc anyhow. The zinc option over phosphate would be convenient. They're 1/2 hour away. http://apexanodizing.com/service-det...c-plating.html
Tony
Old 09-24-2017, 12:19 AM   #5816
OregonNed
OregonNed's Avatar
Looks great!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 09-29-2017, 10:58 AM   #5817
UNEASYRIDER
UNEASYRIDER's Avatar
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 09-29-2017, 11:56 AM   #5818
Ekliptix
Ekliptix's Avatar
Installed new CPP shocks to try to improve the ride over the KYBs included with the ECE drop kit. If this doesn't make me happy, it'll be on to the ultra expensive Ride Tech shocks.
Ekliptix is offline
Old 09-29-2017, 11:24 PM   #5819
rsgt
rsgt's Avatar
Finished my headliner with new trim.
rsgt is offline
Old 09-30-2017, 05:16 PM   #5820
prairewolf
put off doing a full powerbrake burnout until my Son can watch and hopefully video tape it. it will all click and happen sometime. also am getting closer to pulling the Buddy Buckets, just need to find a used bolt in something bench to get it done.
p.s life is simple and fun when it is narrowed down to burnouts and a good kid.
eat,work,spend,sleep,repeat.
prairewolf is offline
Old 09-30-2017, 06:40 PM   #5821
Thor94
Replaced my temperature gauge today. Taking out the whole instrument cluster seemed painful, so I went in from underneath the dash. Probably more painful, but it worked.
Thor94 is offline
Old 09-30-2017, 07:21 PM   #5822
Possmguts
Possmguts's Avatar
Smooth gate skin went on today... Little tweeking tomorrow and thats done... then back to the roll pan and tail lights.
Old 09-30-2017, 08:02 PM   #5823
sKnNyPpY
sKnNyPpY's Avatar
Finally got the rear sway bar done on the '71 GMC with replaced 5 pack leafs and DJM flip kit. The sway link ends lined up with two rivets one of which was a total SOB to remove and broke a step bit and a straight carbide bit. Worth it, the ride and turns are so much better, even more noticeable than adding the front sway bar. Didn't have any arm left to take installed pics
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline
Old 10-01-2017, 11:13 PM   #5824
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Ive been working on painting my console but for some reason the SEM spray bombs I'm using start spitting paint so I had to stop today cause the store was closed. The brown with black inside is how this console started out but I went with the parchment inside so it'll be easier to find things. The Cup Holder is from board member PickemUp. The black was rough machine finished stainless and I sprayed it with wrinkle paint to contrast with the stock black gauge surround.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 10-02-2017, 08:35 PM   #5825
Barnfind46
Barnfind46's Avatar
Replaced my drivers side outside door handle. It went to pieces when I was getting in. Almost lasted 50 years! Gave me a reason to check out the new Summit warehouse that they opened in Arlington,Tx. They had them in stock.
Barnfind46 is offline
Closed Thread
