Old 09-20-2017, 08:03 PM   #1
jabos
Winding noise coming from transmission
I have a winding noise coming from my 3 speed transmission, I believe it is the original. I checked the fluid and it seems to be at the proper level. I was wondering if any of you guys would have any thoughts on the noise. The truck is a 1951 chevy 3600 with a 1961 235 engine
jabos is offline   Reply With Quote
Old 09-20-2017, 10:16 PM   #2
Foot Stomper
Foot Stomper's Avatar
Re: Winding noise coming from transmission
I think they all had a whine... part of the experience.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 09-20-2017, 10:17 PM   #3
mr48chev
mr48chev's Avatar
Worn bearings worn gears or a combination there of. The trans in my 77 1 ton makes that kind of sound and will have to be rebuilt.
My ongoing truck projects:
Old 09-21-2017, 04:13 PM   #4
Wrenchbender Ret
If it is noisy in the lower gears & not high gear, it is probably a bearing. Usually the front drive bearing. It is probably needing an o-haul but if you remove it & pull the front brg. retainer, you can examine the bearing for pits or roughness. It can be replaced without a complete disasemble.
Wrenchbender Ret is offline   Reply With Quote
Old 09-21-2017, 07:42 PM   #5
jabos
Thanks guys, I might try the front bearing first and see if that helps. I was thinking it might be a bearing.
