Old 09-16-2017, 03:14 PM   #26
dsraven
Re: task force pics
roger55, nice looking truck, too bad you couldn't get the paint to flatten out.....
kidding, great job and the gaps are sweet too. hopefully I can get mine to that point sometime.
Old 09-18-2017, 10:22 AM   #27
62lwbc10
Re: task force pics
My 58
62lwbc10 is offline   Reply With Quote
Old 09-18-2017, 10:52 AM   #28
dsraven
Re: task force pics
looks pretty nice, I have always liked red trucks.
Old 09-19-2017, 08:04 AM   #29
rustyfive-seven
Re: task force pics
great pics!, I need inspiration too! the FB pages keep me going!
rustyfive-seven is offline   Reply With Quote
Old 09-20-2017, 01:34 PM   #30
CountofMonteCarlo84
Re: task force pics
Originally Posted by my56chevytruck View Post
Hey countofmontecarlo84, what wheels are on yours? Are those American Racing?? And what did you do to set up the stance your truck has? (front & rear)
Yeah, American Racing Torque Thrust II's. 20x10 in the rear and 18x8 in the front. I can't remember the tire sizes at the moment. I will have to look when I get home. You will have to do some fender rolling in the front to be able to turn lock to lock.
Someone asked about the suspension. The front is Flat Out Engineering C4 Corvette subframe system, the rear is stock frame, and a air ride system.
CountofMonteCarlo84 is offline   Reply With Quote
Old 09-20-2017, 02:45 PM   #31
dubie
dubie's Avatar
Re: task force pics
The 56 shop truck I built.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 09-20-2017, 04:48 PM   #32
jams97355
Re: task force pics
http://67-72chevytrucks.com/vboard/a...1&d=1505940443
jams97355 is offline   Reply With Quote
Old 09-20-2017, 08:29 PM   #33
Black_Sheep
Black_Sheep's Avatar
Re: task force pics
The hood was off being louvered when I took this...
Black_Sheep is offline   Reply With Quote
Old 09-22-2017, 12:04 AM   #34
bmar
bmar's Avatar
Re: task force pics
I am not much for bodywork, but installing LS engines is a favorite of mine.
bmar is offline   Reply With Quote
Old 09-22-2017, 11:47 PM   #35
my56chevytruck
my56chevytruck's Avatar
Re: task force pics
Hey Tim, I sure do like the patina. How do you have the suspension set up?? Nice ride.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 09-23-2017, 11:35 AM   #36
Dan in Pasadena
Dan in Pasadena's Avatar
Re: task force pics
Yup, i like it too. Nice truck Tim.
Black Sheep - Can you tell us about the bolts/washers you used to attach your rear fenders? I bought some showy type bolts/washers from here:
http://www.mmsacc-stainless.com/html/truck_items.htm
I havent installed them yet and I'm wondering if I made a mistake buying the flat washers instead of the beveled ones but those were twice as expensive. I'm wondering if you like yours?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-23-2017, 01:54 PM   #37
Black_Sheep
Re: task force pics
I used 3/8 stainless steel fender washers and stainless pan head torx bolts. After the repaint I plan to use the same bolts with smaller diameter stainless washers with nylon washers between the stainless washer and the paint.
I have been using boltdepot.com for specialty hardware to replace all of the mismatched hardware store fasteners throughout the truck.
Old 09-23-2017, 02:30 PM   #38
dsraven
Re: task force pics
hey dubie, nice looking ride and stance. I like the patina on this one as well, not so over the top as some. not usually a patina guy myself. spent too many years driving patina cause the pocketbook was buying groceries instead of paint, haha.
Old 09-23-2017, 02:33 PM   #39
dsraven
Re: task force pics
bmar,
the LS install looks good. I like the way you run the bulkhead connector. is that a piece of the donor firewall that you cut out and use on the "new" application or is that a custom part? would you use a weather cover on the fuse panel or is there no such thing, possibly too big, didn't bother at time of pic?
Old 09-23-2017, 05:35 PM   #40
bmar
bmar's Avatar
Re: task force pics
The firewall plug was changed and the hole needed to be smaller than the old one and it is just a piece of sheet metal.
I once had the fuse panel inside of an old toolbox, but changed over to just mounting the panel on the fender skirt. I have plans of making a cover, but I don't want something that is bolted on. I need to figure out some kind of snap on quick release cover.
Old 09-23-2017, 07:48 PM   #41
DPete
DPete's Avatar
Re: task force pics
Some day, not to far away
56' 3100 shortbed
DPete is offline   Reply With Quote
Old 09-23-2017, 09:03 PM   #42
my56chevytruck
Re: task force pics
I sure like that paint color. Hang in there, it'll be here before you know it.
1940 Ford Dlx Coupe
1969 Mach1
Old 09-23-2017, 09:14 PM   #43
my56chevytruck
Re: task force pics
Dan,
I don't know the bolts you are using, but heres what I've used on my truck's front fenders and rear fenders. Sorry for the poor picture.
Morrie
1940 Ford Dlx Coupe
1969 Mach1
Old 09-23-2017, 10:49 PM   #44
dsraven
Re: task force pics
if using stainless remember it is softer than the steel bolts so the allen heads strip off easier and they may not be as strong as a steel alternative. should be fine for holding fenders and trim on though.
Old 09-23-2017, 10:59 PM   #45
Dan in Pasadena
Re: task force pics
Morrie,
These are the bolts & washers I bought on the left and I think they look good. Better than stock clutchheads in my opinion. BUT, since buying them I've had 2nd thoughts whether I should have bought the beveled washers the supplier offers as an alternative. I think they look better but they're almost twice the price so I'll live with the flat ones.
Yes, I know stainless fasteners are softer. It's because of their nickel content which also makes them rust resistant. Dsraven - I am using those polished button head stainless on the fasteners in the engine compartment that fasten the inner & outer fenders together right on top. And I will use Never seize on them too.
Old 09-23-2017, 11:17 PM   #46
dsraven
Re: task force pics
that should look great on there.
I just dug my inner fenders out. really rusty and beat up. good for the mock up though. figure out where I need to cut them to fit for the new configuration and then transfer the new shape onto a new set of inners.
Old 09-24-2017, 08:31 PM   #47
Black_Sheep
Re: task force pics
Morrie,
Who sells the bolts and beveled washers Dan?
Old 09-24-2017, 08:33 PM   #48
Rickysnickers
Rickysnickers's Avatar
Re: task force pics
Mine
Old 09-24-2017, 10:59 PM   #49
dsraven
Re: task force pics
thanks rickysnickers. nice looking unit. I like the wheel combo.
Old 09-24-2017, 11:38 PM   #50
Dan in Pasadena
Re: task force pics
Use this link. About 2/3rd's down the page.
